upcp -sbf
upcp -sbf
id: ‘apnscp’: no such user
chown: invalid group: ‘root:apnscp’
setpriv: failed to parse reuid: '--regid'
chown: invalid user: ‘apnscp:apnscp’
WARNING: Cache_Mproxy::_connect(): cache: cannot access server
(RedisException) EXCEPTION: Redis server went away
[/usr/local/apnscp/lib/Cache/Mproxy.php:108]
TASK [filesystem/make-mounts : Verify quota package installed] ******************************************************************************************************************************
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: OSError: Curl error (37): Couldn't read a file:// file for file:///etc/pki/rpm-gpg/RPM-GPG-KEY-apnscp [Couldn't open file /etc/pki/rpm-gpg/RPM-GPG-KEY-apnscp]
fatal: [localhost]: FAILED! => {"changed": false, "module_stderr": "Traceback (most recent call last):\n File \"/usr/lib/python3.6/site-packages/dnf/util.py\", line 115, in _urlopen\n repo._repo.downloadUrl(url, fo.fileno())\n File \"/usr/lib64/python3.6/site-packages/libdnf/repo.py\", line 499, in downloadUrl\n return _repo.Repo_downloadUrl(self, url, fd)\nRuntimeError: Curl error (37): Couldn't read a file:// file for file:///etc/pki/rpm-gpg/RPM-GPG-KEY-apnscp [Couldn't open file /etc/pki/rpm-gpg/RPM-GPG-KEY-apnscp]\n\nDuring handling of the above exception, another exception occurred:\n\nTraceback (most recent call last):\n File \"<stdin>\", line 102, in <module>\n File \"<stdin>\", line 94, in _ansiballz_main\n File \"<stdin>\", line 40, in invoke_module\n File \"/usr/lib64/python3.6/runpy.py\", line 205, in run_module\n return _run_module_code(code, init_globals, run_name, mod_spec)\n File \"/usr/lib64/python3.6/runpy.py\", line 96, in _run_module_code\n mod_name, mod_spec, pkg_name, script_name)\n File \"/usr/lib64/python3.6/runpy.py\", line 85, in _run_code\n exec(code, run_globals)\n File \"/tmp/ansible_dnf_payload_jkd9c7vg/ansible_dnf_payload.zip/ansible/modules/packaging/os/dnf.py\", line 1370, in <module>\n File \"/tmp/ansible_dnf_payload_jkd9c7vg/ansible_dnf_payload.zip/ansible/modules/packaging/os/dnf.py\", line 1359, in main\n File \"/tmp/ansible_dnf_payload_jkd9c7vg/ansible_dnf_payload.zip/ansible/modules/packaging/os/dnf.py\", line 1338, in run\n File \"/tmp/ansible_dnf_payload_jkd9c7vg/ansible_dnf_payload.zip/ansible/modules/packaging/os/dnf.py\", line 1242, in ensure\n File \"/usr/lib/python3.6/site-packages/dnf/base.py\", line 2494, in _get_key_for_package\n keys = dnf.crypto.retrieve(keyurl, repo)\n File \"/usr/lib/python3.6/site-packages/dnf/crypto.py\", line 185, in retrieve\n with dnf.util._urlopen(keyurl, repo=repo) as handle:\n File \"/usr/lib/python3.6/site-packages/dnf/util.py\", line 119, in _urlopen\n raise IOError(str(e))\nOSError: Curl error (37): Couldn't read a file:// file for file:///etc/pki/rpm-gpg/RPM-GPG-KEY-apnscp [Couldn't open file /etc/pki/rpm-gpg/RPM-GPG-KEY-apnscp]\n", "module_stdout": "", "msg": "MODULE FAILURE\nSee stdout/stderr for the exact error", "rc": 1}
PLAY RECAP **********************************************************************************************************************************************************************************
localhost : ok=56 changed=0 unreachable=0 failed=1 skipped=28 rescued=0 ignored=0
