Roundcube login page works just fine, but upon a successful login a 404 page is shown ( FILE NOT FOUND The requested resource was not found!). Refreshing the page doesn’t fix it, neither reinstalling the package itself.
Thought of it being a skin issue, but that is not defined/overwritten in the config so doesn’t apply.
ApisCP version:
[root@web5 roundcube]# cpcmd misc:cp-version
revision: e10fcbc17eedca9d8e3f2da549e19cc7b781e8e2
timestamp: 1783621327
ver_pre: 72-ge10fcbc17
Operating System:
[root@web5 roundcube]# uname -r
7.1.3-1.el8.elrepo.x86_64
[root@web5 roundcube]# tail -f /var/lib/roundcube/logs/errors.log
[24-Jan-2023 14:07:21 America/New_York] PHP Deprecated: Return type of zipdownload_mbox_filter::filter($in, $out, &$consumed, $closing) should either be compatible with php_user_filter::filter($in, $out, &$consumed, bool $closing): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /var/www/html/roundcube/plugins/zipdownload/zipdownload.php on line 405
[24-Jan-2023 14:07:21 America/New_York] PHP Deprecated: preg_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in /var/www/html/roundcube/program/lib/Roundcube/bootstrap.php on line 329
[24-Jan-2023 14:07:33 America/New_York] PHP Deprecated: Return type of zipdownload_mbox_filter::filter($in, $out, &$consumed, $closing) should either be compatible with php_user_filter::filter($in, $out, &$consumed, bool $closing): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in /var/www/html/roundcube/plugins/zipdownload/zipdownload.php on line 405
[24-Jan-2023 14:07:33 America/New_York] PHP Deprecated: preg_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in /var/www/html/roundcube/program/lib/Roundcube/bootstrap.php on line 329[13-Jul-2026 11:59:18 +0200]: <0a2dadb7> PHP Error: Error loading template for mail in /var/www/html/roundcube/program/include/rcmail_output_html.php on line 804 (GET /roundcube/?_task=mail&_token=1)
[13-Jul-2026 12:22:55 +0200]: <ae4ddjo6> PHP Error: Error loading template for mail in /var/www/html/roundcube/program/include/rcmail_output_html.php on line 804 (GET /roundcube/?_task=mail&_token=1&_token=2)
[root@web5 roundcube]# ls -la /var/www/html/roundcube/skins/elastic/templates/
total 148
drwxr-xr-x 3 root root 4096 Jul 13 11:59 .
drwxr-xr-x 7 root root 183 Jul 13 11:59 ..
-rw-r--r-- 1 root root 606 Feb 8 10:33 about.html
-rw-r--r-- 1 root root 10421 Feb 8 10:33 addressbook.html
-rw-r--r-- 1 root root 4055 Feb 8 10:33 bounce.html
-rw-r--r-- 1 root root 17577 Feb 8 10:33 compose.html
-rw-r--r-- 1 root root 1236 Feb 8 10:33 contactedit.html
-rw-r--r-- 1 root root 879 Feb 8 10:33 contact.html
-rw-r--r-- 1 root root 425 Feb 8 10:33 contactimport.html
-rw-r--r-- 1 root root 777 Feb 8 10:33 contactprint.html
-rw-r--r-- 1 root root 347 Feb 8 10:33 contactsearch.html
-rw-r--r-- 1 root root 222 Feb 8 10:33 dialog.html
-rw-r--r-- 1 root root 660 Feb 8 10:33 error.html
-rw-r--r-- 1 root root 378 Feb 8 10:33 folderedit.html
-rw-r--r-- 1 root root 3139 Feb 8 10:33 folders.html
-rw-r--r-- 1 root root 2157 Feb 8 10:33 identities.html
-rw-r--r-- 1 root root 442 Feb 8 10:33 identityedit.html
drwxr-xr-x 2 root root 129 Jul 13 11:59 includes
-rw-r--r-- 1 root root 1159 Feb 8 10:33 login.html
-rw-r--r-- 1 root root 13119 Feb 8 10:33 mail.html
-rw-r--r-- 1 root root 4619 Feb 8 10:33 message.html
-rw-r--r-- 1 root root 6988 Feb 8 10:33 messagepart.html
-rw-r--r-- 1 root root 987 Feb 8 10:33 messageprint.html
-rw-r--r-- 1 root root 573 Feb 8 10:33 plugin.html
-rw-r--r-- 1 root root 443 Feb 8 10:33 responseedit.html
-rw-r--r-- 1 root root 2024 Feb 8 10:33 responses.html
-rw-r--r-- 1 root root 394 Feb 8 10:33 settingsedit.html
-rw-r--r-- 1 root root 1273 Feb 8 10:33 settings.html
