v3.2.49.2 & CVE-2026-109618 + CVE-2026-109619
TASK [php/build-from-source : Remove older PHPs] ************************************************************************************************************
skipping: [localhost] => (item=Removing php-8.2.35)  => {"ansible_loop_var": "item", "changed": false, "item": {"atime": 1792598776.2525148, "ctime": 1792731835.1734939, "dev": 64513, "gid": 65534, "gr_name": "nobody", "inode": 23833533, "isblk": false, "ischr": false, "isdir": true, "isfifo": false, "isgid": false, "islnk": false, "isreg": false, "issock": false, "isuid": false, "mode": "0755", "mtime": 1792731835.1734939, "nlink": 20, "path": "/var/cache/httpd/php-8.2.35", "pw_name": "nobody", "rgrp": true, "roth": true, "rusr": true, "size": 4096, "uid": 65534, "wgrp": false, "woth": false, "wusr": true, "xgrp": true, "xoth": true, "xusr": true}, "skip_reason": "Conditional result was False"}
skipping: [localhost] => (item=Removing php-8.3.36)  => {"ansible_loop_var": "item", "changed": false, "item": {"atime": 1792599205.7092488, "ctime": 1792645699.5983834, "dev": 64513, "gid": 65534, "gr_name": "nobody", "inode": 28660909, "isblk": false, "ischr": false, "isdir": true, "isfifo": false, "isgid": false, "islnk": false, "isreg": false, "issock": false, "isuid": false, "mode": "0775", "mtime": 1792645699.5983834, "nlink": 21, "path": "/var/cache/httpd/php-8.3.36", "pw_name": "nobody", "rgrp": true, "roth": true, "rusr": true, "size": 4096, "uid": 65534, "wgrp": true, "woth": false, "wusr": true, "xgrp": true, "xoth": true, "xusr": true}, "skip_reason": "Conditional result was False"}
skipping: [localhost] => (item=Removing php-8.5.12)  => {"ansible_loop_var": "item", "changed": false, "item": {"atime": 1792599635.2179682, "ctime": 1792646079.5901532, "dev": 64513, "gid": 65534, "gr_name": "nobody", "inode": 28790509, "isblk": false, "ischr": false, "isdir": true, "isfifo": false, "isgid": false, "islnk": false, "isreg": false, "issock": false, "isuid": false, "mode": "0775", "mtime": 1792646079.5901532, "nlink": 19, "path": "/var/cache/httpd/php-8.5.12", "pw_name": "nobody", "rgrp": true, "roth": true, "rusr": true, "size": 4096, "uid": 65534, "wgrp": true, "woth": false, "wusr": true, "xgrp": true, "xoth": true, "xusr": true}, "skip_reason": "Conditional result was False"}
TASK [php/build-from-source : Remove PHP configuration directory] *******************************************************************************************
skipping: [localhost] => {"changed": false, "skip_reason": "Conditional result was False"}
TASK [php/build-from-source : Include apxs] *****************************************************************************************************************
TASK [php/build-from-source : Reduce max concurrent jobs] ***************************************************************************************************
TASK [Attach temporary swap] ********************************************************************************************************************************
TASK [php/build-from-source : Flag swap handler] ************************************************************************************************************
TASK [php/build-from-source : set_fact] *********************************************************************************************************************
ok: [localhost] => {"ansible_facts": {"force_module_rebuild": true}, "changed": false}
TASK [php/build-from-source : include_tasks] ****************************************************************************************************************
included: /usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/build-php.yml for localhost
TASK [php/build-from-source : stat] *************************************************************************************************************************
ok: [localhost] => {"changed": false, "stat": {"atime": 1792598190.5522385, "attr_flags": "e", "attributes": ["extents"], "block_size": 4096, "blocks": 8, "charset": "binary", "ctime": 1792690438.5120149, "dev": 64513, "device_type": 0, "executable": true, "exists": true, "gid": 65534, "gr_name": "nobody", "inode": 16875716, "isblk": false, "ischr": false, "isdir": true, "isfifo": false, "isgid": false, "islnk": false, "isreg": false, "issock": false, "isuid": false, "mimetype": "inode/directory", "mode": "0755", "mtime": 1792690438.5120149, "nlink": 19, "path": "/var/cache/httpd/php-8.4.27", "pw_name": "nobody", "readable": true, "rgrp": true, "roth": true, "rusr": true, "size": 4096, "uid": 65534, "version": "1615392291", "wgrp": false, "woth": false, "writeable": true, "wusr": true, "xgrp": true, "xoth": true, "xusr": true}}
TASK [php/build-from-source : Download PHP 8.4.27] **********************************************************************************************************
TASK [php/build-from-source : Apply per-version patches] ****************************************************************************************************
included: /usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/apply-patches.yml for localhost
TASK [php/build-from-source : Enumerate all patches] ********************************************************************************************************
fatal: [localhost]: FAILED! => {"msg": "Unexpected templating type error occurred on ({{ php_patch_candidates | selectattr('when', 'defined') | selectattr('when') | list | map(attribute='name') + php_patch_candidates | rejectattr('when', 'defined') | list | map(attribute='name') + (query('fileglob', __php_patch_dir ~ '/[0-9]*-PHP-' ~ __php_minor ~ '-*') + query('fileglob', __php_patch_dir ~ '/[0-9]*-PHP-' ~ version ~ '-*')) | map('basename') | list }}): unsupported operand type(s) for +: 'generator' and 'generator'"}
PLAY RECAP **************************************************************************************************************************************************
localhost                  : ok=262  changed=16   unreachable=0    failed=1    skipped=149  rescued=0    ignored=0
Thanks. I’ll look into this once time permits.
I’m still unable to reproduce on EL8 and EL10. PHP 8.4 is a system build (cpcmd scope:get php.version).
Here’s my readout from ansible --version:
ansible [core 2.16.16]
  config file = /etc/ansible/ansible.cfg
  configured module search path = ['/root/.ansible/plugins/modules', '/usr/share/ansible/plugins/modules']
  ansible python module location = /usr/lib/python3.12/site-packages/ansible
  ansible collection location = /root/.ansible/collections:/usr/share/ansible/collections
  executable location = /usr/bin/ansible
  python version = 3.12.15 (main, Oct  1 2026, 00:00:00) [GCC 14.3.1 20251022 (Red Hat 14.3.1-4)] (/usr/bin/python3)
  jinja version = 3.1.6
  libyaml = True
Edit: let me check another machine that’s more pristine. Dev is EL8 but Ansible 2.12. EL8 distro default is 2.9. Might be a type coercion oddity in 2.9…
Edit 2x: yep, best reference I can find is ansible/ansible#78209 that coercion is discretion of maintainers. I’ve added a separate explicit cast that resolves this going forward.
Run upcp -b php/install; ought to be fixed now.
PHP = 8.4
Ansible = 2.9.27
It made it much farther this time. It applied patches to 8.1 and then died on 8.2
Still just running a upcp -sbf, there was a failure the other day on 8.5 and by the time I had a chance to run it again you released the update that does patches and its failed ever since.
TASK [php/install-pecl-module : Build and install imagick library.] *****************************************************************************************
changed: [localhost]
included: /usr/local/apnscp/resources/playbooks/roles/php/install-extensions/tasks/populate-module-ini.yml for localhost
TASK [php/build-from-source : Apply PHP 8.2.35 patches] *****************************************************************************************************
failed: [localhost] (item=Apply [) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access '['\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/[\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/[\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/[\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/[\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/[\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/[\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/[\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/[\n\t/usr/local/apnscp/resources/playbooks/files/[\n\t/usr/local/apnscp/resources/playbooks/[ on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "["}
failed: [localhost] (item=Apply ]) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access ']'\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/]\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/]\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/]\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/]\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/]\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/]\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/]\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/]\n\t/usr/local/apnscp/resources/playbooks/files/]\n\t/usr/local/apnscp/resources/playbooks/] on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "]"}
failed: [localhost] (item=Apply A) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access 'A'\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/A\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/A\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/A\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/A\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/A\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/A\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/A\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/A\n\t/usr/local/apnscp/resources/playbooks/files/A\n\t/usr/local/apnscp/resources/playbooks/A on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "A"}
failed: [localhost] (item=Apply b) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access 'b'\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/b\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/b\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/b\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/b\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/b\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/b\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/b\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/b\n\t/usr/local/apnscp/resources/playbooks/files/b\n\t/usr/local/apnscp/resources/playbooks/b on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "b"}
failed: [localhost] (item=Apply d) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access 'd'\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/d\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/d\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/d\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/d\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/d\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/d\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/d\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/d\n\t/usr/local/apnscp/resources/playbooks/files/d\n\t/usr/local/apnscp/resources/playbooks/d on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "d"}
failed: [localhost] (item=Apply e) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access 'e'\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/e\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/e\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/e\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/e\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/e\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/e\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/e\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/e\n\t/usr/local/apnscp/resources/playbooks/files/e\n\t/usr/local/apnscp/resources/playbooks/e on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "e"}
failed: [localhost] (item=Apply f) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access 'f'\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/f\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/f\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/f\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/f\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/f\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/f\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/f\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/f\n\t/usr/local/apnscp/resources/playbooks/files/f\n\t/usr/local/apnscp/resources/playbooks/f on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "f"}
failed: [localhost] (item=Apply i) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access 'i'\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/i\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/i\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/i\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/i\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/i\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/i\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/i\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/i\n\t/usr/local/apnscp/resources/playbooks/files/i\n\t/usr/local/apnscp/resources/playbooks/i on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "i"}
failed: [localhost] (item=Apply l) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access 'l'\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/l\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/l\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/l\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/l\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/l\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/l\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/l\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/l\n\t/usr/local/apnscp/resources/playbooks/files/l\n\t/usr/local/apnscp/resources/playbooks/l on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "l"}
failed: [localhost] (item=Apply n) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access 'n'\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/n\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/n\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/n\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/n\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/n\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/n\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/n\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/n\n\t/usr/local/apnscp/resources/playbooks/files/n\n\t/usr/local/apnscp/resources/playbooks/n on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "n"}
failed: [localhost] (item=Apply s) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access 's'\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/s\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/s\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/s\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/s\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/s\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/s\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/s\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/s\n\t/usr/local/apnscp/resources/playbooks/files/s\n\t/usr/local/apnscp/resources/playbooks/s on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "s"}
failed: [localhost] (item=Apply U) => {"ansible_loop_var": "patch", "changed": false, "msg": "Could not find or access 'U'\nSearched in:\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/U\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/U\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/files/U\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/U\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/files/U\n\t/usr/local/apnscp/resources/playbooks/roles/php/multiphp/U\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/files/U\n\t/usr/local/apnscp/resources/playbooks/roles/php/build-from-source/tasks/U\n\t/usr/local/apnscp/resources/playbooks/files/U\n\t/usr/local/apnscp/resources/playbooks/U on the Ansible Controller.\nIf you are using a module and expect the file to exist on the remote, see the remote_src option", "patch": "U"}
localhost                  : ok=1041 changed=70   unreachable=0    failed=1    skipped=552  rescued=0    ignored=0
I can open a new issue, but was just replying to this one since it’s where you listed the new patches functionality.
Fixed. :+1:
Confirmed, although the run failed because it tried to create an admin at the end, but all the PHP tasks completed which is what my concern was.
Thanks for being so attentive to this matter.
Trying to run this update on a headless server:
TASK [common/migrate : Locate migration files] *********************************
included: /usr/local/apnscp/resources/playbooks/migrations/2026_10_20_205611_php-cve-2026-10961x.yml for localhost
TASK [common/migrate : shell] **************************************************
fatal: [localhost]: FAILED! => changed=true
  cmd: for i in /etc/php[5-8]*.d ; do echo -e '[session]\nsession.upload_progress.enabled=0' > $i/cve-2026-109618.ini ; done ; systemctl restart php-fpm
  delta: '0:00:00.084720'
  end: '2026-11-14 18:20:07.580876'
  msg: non-zero return code
  rc: 5
  start: '2026-11-14 18:20:07.496156'
  stderr: 'Failed to restart php-fpm.service: Unit php-fpm.service not found.'
  stderr_lines: <omitted>
  stdout: ''
  stdout_lines: <omitted>
localhost                  : ok=6    changed=0    unreachable=0    failed=1    skipped=3    rescued=0    ignored=0
STDERR:
[/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:212]
         0. Lararia\Database\Migrations\PlatformMigrator->runMigration("2026_10_20_205611_php-cve-2026-10961x", "up", [step:true])
            [/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:129]
         1. Lararia\Database\Migrations\PlatformMigrator->runUp("/usr/local/apnscp/resources/playbooks/migrations/2026_10_20_205611_php-cve-2026-10961x.yml", 59, false)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:165]
         2. Illuminate\Database\Migrations\Migrator->runPending(["/usr/local/apnscp/resources/playbooks/migrations/2026_10_20_205611_php-cve-2026-10961x.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_10_22_082138_eol-php-update.yml"], [pretend:false, step:0, rollback:false, ff:false])
            [/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:93]
Give it a go on edge…
env UPDATE_POLICY=edge upcp
That will perform a one-off update on edge while successfully completing the necessary migration from 3.2.49.
