Apache not starting
Hey everyone,
I’ve been trying to get my Apache server set up with Apiscp, but I’m running into some issues with getting my main domain (https://krlit.co.uk/) to properly point to my WordPress site, while my subdomain (https://panel.krlit.co.uk/) should point to the Apiscp control panel.
I’ve configured the DNS records (Hosted on Namecheap) correctly (pointing both A records for krlit.co.uk and panel.krlit.co.uk to my server IP) and I’ve set up VirtualHosts.
But the main domain is still pointing to the Apiscp panel and i cannot figure it out. Is it possible or do i need a reverse proxy or edit .htaccess file?
Asked chatgpt, it told me to edit the virtualhost file. I went into edit this and it said dont edit, only edit .conf file. I did this but now apache not starting. But syntax is passing.
Want my correct domains to go to the correct locations. And apache to start.
both domain/subdomain go to the panel
ApisCP version: revision: 4921e9dac660d66dccd58c0ef39b44009bb9819d
timestamp: 1738426006
ver_pre: 4921e9dac
Operating System: 4.18.0-553.36.1.el8_10.x86_64
Provide any additional information about the bug, such as error messages, logs, screenshots, or any other relevant details.
[root@panel apnscp]# htrebuild
Reloading httpd: Syntax OK
httpd not running, trying to start
no listening sockets available, shutting down
AH00015: Unable to open logs
Sounds like you have another daemon listening on port 80/443 or the machine is on a floating IP and the IP changed.
If the internal IP changed, see NAT/Private networks > Changing IPs
To check if another service is listening on port 80/443 - shouldn’t be the case:
ss -lptn 'sport = :80 || sport = :443'
