Apache wont Start, error on mod_passenger
Apache wont start
Got alerts about apache after a system health check. No manual action was done.
Apache to start
Tried restarting the server, disabling and reenabling Passenger but the error persists.
revision: 3ec2e7884c258580fa707cfe827a4269861007c6
timestamp: 1730519492
ver_patch: 45
ver_pre: ‘’
Operating System: uname -r
NAME=“AlmaLinux”
VERSION=“8.10 (Cerulean Leopard)”
ID=“almalinux”
ID_LIKE=“rhel centos fedora”
VERSION_ID=“8.10”
PLATFORM_ID=“platform:el8”
PRETTY_NAME=“AlmaLinux 8.10 (Cerulean Leopard)”
ANSI_COLOR=“0;34”
LOGO=“fedora-logo-icon”
CPE_NAME=“cpe:/o:almalinux:almalinux:8::baseos”
HOME_URL=“https://almalinux.org/”
DOCUMENTATION_URL=“https://wiki.almalinux.org/”
BUG_REPORT_URL=“https://bugs.almalinux.org/”
[root@server ~]# PAGER=cat systemctl -l status httpd
● httpd.service - The Apache HTTP Server
Loaded: loaded (/usr/lib/systemd/system/httpd.service; enabled; vendor preset: disabled)
Drop-In: /etc/systemd/system/httpd.service.d
└─override.conf
Active: failed (Result: protocol) since Sat 2025-02-01 03:58:02 -05; 7s ago
Process: 80507 ExecStart=/etc/systemd/user/httpd.init start (code=exited, status=0/SUCCESS)
Process: 80506 ExecStartPre=/bin/sh -c test -d /run/httpd || /usr/bin/mkdir /run/httpd (code=exited, status=0/SUCCESS)
Feb 01 03:58:02 server.apiscp httpd.init[80521]: Starting httpd:
Feb 01 03:58:02 server.apiscp httpd.init[80521]: ttpd: Syntax error on line 409 of /etc/httpd/conf/httpd.conf: Syntax error on line 11 of /etc/httpd/conf.d/passenger.conf: Cannot load /.socket/passenger/buildout/apache2/mod_passenger.so into server: /.socket/passenger/buildout/apache2/mod_passenger.so: cannot open shared object file: No such fi
Feb 01 03:58:02 server.apiscp httpd.init[80516]: ttpd: Syn(forcibly terminating…)
Feb 01 03:58:02 server.apiscp httpd.init[80538]: ttpd: Syn(forcibly terminating…)
Feb 01 03:58:02 server.apiscp httpd.init[80538]: ttpd: Syntax error on line 409 of /etc/httpd/conf/httpd.conf: Syntax error on line 11 of /etc/httpd/conf.d/passenger.conf: Cannot load /.socket/passenger/buildout/apache2/mod_passenger.so into server: /.socket/passenger/buildout/apache2/mod_passenger.so: cannot open shared obje
Feb 01 03:58:02 server.apiscp httpd.init[80507]: t
Feb 01 03:58:02 server.apiscp systemd[1]: httpd.service: Can’t open PID file /run/httpd.pid (yet?) after start: No such file or directory
Feb 01 03:58:02 server.apiscp systemd[1]: httpd.service: Failed with result ‘protocol’.
Feb 01 03:58:02 server.apiscp systemd[1]: Failed to start The Apache HTTP Server.
What does upcp -sb software/passenger report?
PLAY [localhost] *******************************************************************************************
included: /usr/local/apnscp/resources/playbooks/roles/software/passenger/tasks/passenger-surrogate.yml for localhost
[WARNING]: flush_handlers task does not support when conditional
PLAY RECAP *************************************************************************************************
localhost : ok=18 changed=0 unreachable=0 failed=0 skipped=7 rescued=0 ignored=0
Run this:
upcp -b software/passenger
Good to go now?
Still won’t start:
[root@server ~]# cpcmd scope:set cp.update-policy edge-major
INFO : Bootstrapper task running in background with roles: apnscp/crons, apnscp/install-services
[root@server ~]# upcp -b software/passenger
remote: Enumerating objects: 36, done.
remote: Counting objects: 100% (36/36), done.
remote: Compressing objects: 100% (19/19), done.
remote: Total 19 (delta 15), reused 0 (delta 0), pack-reused 0 (from 0)
Unpacking objects: 100% (19/19), 2.70 KiB | 230.00 KiB/s, done.
From apisnetworks / ApisCP · GitLab
d4be92c8e…4921e9dac master → origin/master
  • branch master → FETCH_HEAD
    hint: You have divergent branches and need to specify how to reconcile them.
    hint: You can do so by running one of the following commands sometime before
    hint: your next pull:
    hint:
    hint: git config pull.rebase false # merge
    hint: git config pull.rebase true # rebase
    hint: git config pull.ff only # fast-forward only
    hint:
    hint: You can replace “git config” with “git config --global” to set a default
    hint: preference for all repositories. You can also pass --rebase, --no-rebase,
    hint: or --ff-only on the command line to override the configured default per
    hint: invocation.
    fatal: Need to specify how to reconcile divergent branches.
    Reasserting permissions
    storage/.edge.lock
    storage/opcenter/mappings/domainmap.tch
    storage/cache/config.php
    storage/run/apnscpd.pid
    storage/run/httpd.pid
    storage/tmp/agent-root
    .git/index
    hint:
    hint:
    hint: invocation.
    Compiled services and packages files removed!
    Nothing to migrate.
    Nothing to migrate.
Pausing for 30 seconds
(ctrl+C then ‘C’ = continue early, ctrl+C then ‘A’ = abort)
[common/acquire-lock : Verify process matches ansible]
Ansible running with PID 148455.
Start time: 2025-02-01 12:48:14
Waiting for completion. My PID: 148644.
[WARNING]: Unable to find ‘/proc/148455/comm’ in expected paths (use -vvvvv to see paths)
localhost : ok=19 changed=0 unreachable=0 failed=0 skipped=6 rescued=0 ignored=0
└─override.conf
Active: failed (Result: protocol) since Sat 2025-02-01 12:49:25 -05; 15s ago
Process: 151672 ExecStart=/etc/systemd/user/httpd.init start (code=exited, status=0/SUCCESS)
Process: 151671 ExecStartPre=/bin/sh -c test -d /run/httpd || /usr/bin/mkdir /run/httpd (code=exited, status=0/SUCCESS)
Feb 01 12:49:25 server.apiscp httpd.init[151686]: Starting httpd:
Feb 01 12:49:25 server.apiscp httpd.init[151686]: ttpd: Syntax error on line 409 of /etc/httpd/conf/httpd.conf: Syntax error on line 11 of /etc/httpd/conf.d/passenger.conf: Cannot load /.socket/passenger/buildout/apache2/mod_passenger.so into server: /.socket/passenger/buildout/apache2/mod_passenger.so: cannot open shared object file: No such fi
Feb 01 12:49:25 server.apiscp httpd.init[151681]: ttpd: Syn(forcibly terminating…)
Feb 01 12:49:25 server.apiscp httpd.init[151703]: ttpd: Syn(forcibly terminating…)
Feb 01 12:49:25 server.apiscp httpd.init[151703]: ttpd: Syntax error on line 409 of /etc/httpd/conf/httpd.conf: Syntax error on line 11 of /etc/httpd/conf.d/passenger.conf: Cannot load /.socket/passenger/buildout/apache2/mod_passenger.so into server: /.socket/passenger/buildout/apache2/mod_passenger.so: cannot open shared obje
Feb 01 12:49:25 server.apiscp httpd.init[151672]: t
Feb 01 12:49:25 server.apiscp systemd[1]: httpd.service: Can’t open PID file /run/httpd.pid (yet?) after start: No such file or directory
Feb 01 12:49:25 server.apiscp systemd[1]: httpd.service: Failed with result ‘protocol’.
Feb 01 12:49:25 server.apiscp systemd[1]: Failed to start The Apache HTTP Server.
Run this:
cd /usr/local/apnscp
git status
git checkout master
git pull
# if this errors run:
git reset --hard origin/master
# run role again:
Yeah, I noticed there’s some local changes??
HEAD detached at v3.2.45.2
Changes not staged for commit:
  (use "git add <file>..." to update what will be committed)
  (use "git restore <file>..." to discard changes in working directory)
        modified:   resources/templates/plans/.skeleton/crontab
Untracked files:
  (use "git add <file>..." to include in what will be committed)
        lib/Opcenter/Dns/Providers/Powerdns
        share/
        storage/screenshots/
        storage/themes/apnscp.png
        storage/themes/classic.png
        storage/themes/launchpad.png
        storage/themes/material.png
        storage/themes/obsidian.png
So i did a checkout and reset --hard
git status
On branch master
Your branch is up to date with 'origin/master'.
Untracked files:
        share/
nothing added to commit but untracked files present (use "git add" to track)
But now upcp fails on pyenv because of local changes also?? I attached the full log at the bottom of the post.
[1/1] TASK [/usr/local/apnscp/resources/playbooks/roles/software/pyenv/../pyenv-support : Clone pyenv repository] ***
  before: 734d6323d8fda6998b0dcd87e8871c8bec189b72
  msg: Local modifications exist in repository (force=no).
Then I tried disabling Passenger again, but still no luck with apache.
cpcmd scope:set cp.bootstrapper passenger_enabled false
upcp -sb
Finally I tried “upcp -b software/passenger” again.
And now apache is UP!
I have no use of Passenger right now but would like to know if it would be safe to enable it in the future again.
Full log of upcp after reset --hard:
Nothing to migrate.
Migrating: 2024_12_13_145213_pyenv-switch
[0/1] PLAY [localhost] ***************************************************************
[0/1] TASK [Gathering Facts] *********************************************************
ok: [localhost]
[0/1] TASK [common/acquire-lock : Validate lock existence] ***************************
ok: [localhost]
[0/1] TASK [common/acquire-lock : Acquire lock] **************************************
skipping: [localhost]
[0/1] TASK [common/acquire-lock : set_fact] ******************************************
ok: [localhost]
[0/1] TASK [common/acquire-lock : Check if PID /proc/235296/comm present] ************
ok: [localhost]
[0/1] TASK [common/acquire-lock : Verify process matches ansible] ********************
[0/1] TASK [common/acquire-lock : Save PID in /usr/local/apnscp/storage/run/.ansible.lock] ***
ok: [localhost]
[0/1] TASK [common/migrate : Gather all migration files] *****************************
[0/1] TASK [common/migrate : Locate migration files] *********************************
included: /usr/local/apnscp/resources/playbooks/migrations/2024_12_13_145213_pyenv-switch.yml for localhost
[1/1] TASK [common/migrate : Move reseller_id to id] *********************************
changed: [localhost]
[1/1] TASK [common/migrate : Rename reseller_id within plans] ************************
[1/1] TASK [common/migrate : Clobber pyenv git tags] *********************************
[1/1] TASK [Update pyenv source] *****************************************************
[1/1] TASK [software/pyenv : Enable any-version Python] ******************************
included: /usr/local/apnscp/resources/playbooks/roles/software/pyenv/tasks/enable-pyenv.yml for localhost
[1/1] TASK [software/pyenv : set_fact] ***********************************************
ok: [localhost]
[1/1] TASK [software/pyenv : Prepare /usr/local/share/python/pyenv] ******************
ok: [localhost]
[1/1] TASK [Install pyenv] ***********************************************************
[1/1] TASK [/usr/local/apnscp/resources/playbooks/roles/software/pyenv/../pyenv-support : Create directories] ***
ok: [localhost]
[1/1] PLAY RECAP *********************************************************************
localhost                  : ok=13   changed=3    unreachable=0    failed=1    skipped=3    rescued=0    ignored=0
(RuntimeException) EXCEPTION: STDOUT:
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
STDERR:
[/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:211]
         0. Lararia\Database\Migrations\PlatformMigrator->runMigration("2024_12_13_145213_pyenv-switch", "up", [step:true])
            [/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:128]
         1. Lararia\Database\Migrations\PlatformMigrator->runUp("/usr/local/apnscp/resources/playbooks/migrations/2024_12_13_145213_pyenv-switch.yml", 7, false)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:165]
         2. Illuminate\Database\Migrations\Migrator->runPending(["/usr/local/apnscp/resources/playbooks/migrations/2024_12_13_145213_pyenv-switch.yml", "/usr/local/apnscp/resources/playbooks/migrations/2024_12_26_113057_catchall-transport-delivery.yml"], [pretend:false, step:0, rollback:false, ff:false])
            [/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:92]
         3. Lararia\Database\Migrations\PlatformMigrator->runPending(["/usr/local/apnscp/resources/playbooks/migrations/2024_12_13_145213_pyenv-switch.yml", "/usr/local/apnscp/resources/playbooks/migrations/2024_12_26_113057_catchall-transport-delivery.yml"], [pretend:false, step:0, rollback:false, ff:false])
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:110]
         4. Illuminate\Database\Migrations\Migrator->run(["/usr/local/apnscp/resources/playbooks/migrations"], [pretend:false, step:0, rollback:false, ff:false])
            [/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:40]
         5. Lararia\Database\Migrations\PlatformMigrator->run(["/usr/local/apnscp/resources/playbooks/migrations"], [pretend:false, step:0, rollback:false, ff:false])
            [/usr/local/apnscp/lib/Lararia/Console/Commands/PlatformMigration.php:76]
         6. Lararia\Console\Commands\PlatformMigration->handle()
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:36]
         7. Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/Util.php:37]
         8. Illuminate\Container\Util::unwrapIfClosure()
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:93]
         9. Illuminate\Container\BoundMethod::callBoundMethod(Lararia\Application, [], [Lararia\Console\Commands\PlatformMigration, "handle"], )
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:37]
        10. Illuminate\Container\BoundMethod::call(Lararia\Application, [], [Lararia\Console\Commands\PlatformMigration, "handle"], null)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/Container.php:590]
        11. Illuminate\Container\Container->call([Lararia\Console\Commands\PlatformMigration, "handle"])
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Command.php:134]
        12. Illuminate\Console\Command->execute(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Command/Command.php:255]
        13. Symfony\Component\Console\Command\Command->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Command.php:121]
        14. Illuminate\Console\Command->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Application.php:1021]
        15. Symfony\Component\Console\Application->doRunCommand(Lararia\Console\Commands\PlatformMigration, Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Application.php:275]
        16. Symfony\Component\Console\Application->doRun(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Application.php:149]
        17. Symfony\Component\Console\Application->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Application.php:93]
        18. Illuminate\Console\Application->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Application.php:185]
        19. Illuminate\Console\Application->call("migrate:platform", [--force:true, --pretend:false], Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:273]
        20. Illuminate\Foundation\Console\Kernel->call("migrate:platform", [--force:true, --pretend:false], Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php:261]
        21. Illuminate\Support\Facades\Facade::__callStatic("call", ["migrate:platform", [[--force:true, --pretend:false], Illuminate\Console\OutputStyle]])
            [/usr/local/apnscp/lib/Lararia/Console/Commands/Migrate.php:55]
        22. Lararia\Console\Commands\Migrate->handle()
        23. Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
        24. Illuminate\Container\Util::unwrapIfClosure()
        25. Illuminate\Container\BoundMethod::callBoundMethod(Lararia\Application, [], [Lararia\Console\Commands\Migrate, "handle"], )
        26. Illuminate\Container\BoundMethod::call(Lararia\Application, [], [Lararia\Console\Commands\Migrate, "handle"], null)
        27. Illuminate\Container\Container->call([Lararia\Console\Commands\Migrate, "handle"])
        28. Illuminate\Console\Command->execute(Symfony\Component\Console\Input\ArgvInput, Illuminate\Console\OutputStyle)
        29. Symfony\Component\Console\Command\Command->run(Symfony\Component\Console\Input\ArgvInput, Illuminate\Console\OutputStyle)
        30. Illuminate\Console\Command->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        31. Symfony\Component\Console\Application->doRunCommand(Lararia\Console\Commands\Migrate, Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        32. Symfony\Component\Console\Application->doRun(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        33. Symfony\Component\Console\Application->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        34. Illuminate\Console\Application->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:131]
        35. Illuminate\Foundation\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
            [/usr/local/apnscp/lib/Lararia/Console/Kernel.php:31]
        36. Lararia\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
            [/usr/local/apnscp/artisan:60]
type or paste code here
