[root@cpanel apnscp]# cd /usr/local/apnscp
[root@cpanel apnscp]# git checkout v3.2.36
M lib/Auth/SASL/DigestMD5.php
M lib/HTTP/Request2/Adapter/Socket.php
M lib/html/ajax/functions.php
Previous HEAD position was d849b1c2 FIX: default nullable (Sql)
HEAD is now at ff670fed CHG: DEBUG_PROC happens too early (Util\Process)
[root@cpanel apnscp]# service apnscp restart
Redirecting to /bin/systemctl restart apnscp.service
Job for apnscp.service failed because the control process exited with error code.
See “systemctl status apnscp.service” and “journalctl -xe” for details.
[root@cpanel apnscp]# ./artisan migrate --force && upcp
Failed loading /usr/local/apnscp/sys/php/20190902-zts/opcache.so: /usr/local/apnscp/sys/php/20190902-zts/opcache.so: undefined symbol: zend_signal_globals_offset
PHP Warning: PHP Startup: Unable to load dynamic library ‘apcu.so’ (tried: /usr/local/apnscp/sys/php/20190902-zts/apcu.so (/usr/local/apnscp/sys/php/20190902-zts/apcu.so: undefined symbol: executor_globals_offset), /usr/local/apnscp/sys/php/20190902-zts/apcu.so.so (/usr/local/apnscp/sys/php/20190902-zts/apcu.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘igbinary.so’ (tried: /usr/local/apnscp/sys/php/20190902-zts/igbinary.so (/usr/local/apnscp/sys/php/20190902-zts/igbinary.so: undefined symbol: core_globals_offset), /usr/local/apnscp/sys/php/20190902-zts/igbinary.so.so (/usr/local/apnscp/sys/php/20190902-zts/igbinary.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘redis.so’ (tried: /usr/local/apnscp/sys/php/20190902-zts/redis.so (/usr/local/apnscp/sys/php/20190902-zts/redis.so: undefined symbol: executor_globals_offset), /usr/local/apnscp/sys/php/20190902-zts/redis.so.so (/usr/local/apnscp/sys/php/20190902-zts/redis.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘dbus.so’ (tried: /usr/local/apnscp/sys/php/20190902-zts/dbus.so (/usr/local/apnscp/sys/php/20190902-zts/dbus.so: cannot open shared object file: No such file or directory), /usr/local/apnscp/sys/php/20190902-zts/dbus.so.so (/usr/local/apnscp/sys/php/20190902-zts/dbus.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘event.so’ (tried: /usr/local/apnscp/sys/php/20190902-zts/event.so (/usr/local/apnscp/sys/php/20190902-zts/event.so: undefined symbol: executor_globals_offset), /usr/local/apnscp/sys/php/20190902-zts/event.so.so (/usr/local/apnscp/sys/php/20190902-zts/event.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
WARNING: dl(): Unable to load dynamic library ‘igbinary.so’ (tried: /usr/local/apnscp/sys/php/20190902-zts/igbinary.so (/usr/local/apnscp/sys/php/20190902-zts/igbinary.so: undefined symbol: core_globals_offset), /usr/local/apnscp/sys/php/20190902-zts/igbinary.so.so (/usr/local/apnscp/sys/php/20190902-zts/igbinary.so.so: cannot open shared object file: No such file or directory))
[/usr/local/apnscp/lib/apnscpcore.php:95]
0. Error_Reporter::handle_error(2, "dl(): Unable to load dynamic library 'igbinary.so' (tried: /usr/local/apnscp/sys/php/20190902-zts/igbinary.so (/usr/local/apnscp/sys/php/20190902-zts/igbinary.so: undefined symbol: core_globals_offset), /usr/local/apnscp/sys/php/20190902-zts/igbinary.so.so (/usr/local/apnscp/sys/php/20190902-zts/igbinary.so.so: cannot open shared object file: No such file or directory))", "/usr/local/apnscp/lib/apnscpcore.php", 95, [[[[[["./artisan", "migrate", "--force"]]]]]])
[n/a]
1. dl("igbinary.so")
2. include("/usr/local/apnscp/lib/apnscpcore.php")
[/usr/local/apnscp/artisan:19]
fatal: igbinary extension not loadedUpdating to v3.2.36.1
Previous HEAD position was ff670fed CHG: DEBUG_PROC happens too early (Util\Process)
HEAD is now at ca1b769d CHG: rebuild sites with missing sockets (migrations)
[/usr/local/apnscp/lib/apnscpcore.php:98]
0. Error_Reporter::handle_error(2, "dl(): Unable to load dynamic library 'igbinary.so' (tried: /usr/local/apnscp/sys/php/20190902-zts/igbinary.so (/usr/local/apnscp/sys/php/20190902-zts/igbinary.so: undefined symbol: core_globals_offset), /usr/local/apnscp/sys/php/20190902-zts/igbinary.so.so (/usr/local/apnscp/sys/php/20190902-zts/igbinary.so.so: cannot open shared object file: No such file or directory))", "/usr/local/apnscp/lib/apnscpcore.php", 98, [[[[[["./artisan", "migrate", "--force"]]]]]])
[n/a]
fatal: igbinary extension not loadedUpdating to v3.2.36.2
Previous HEAD position was ca1b769d CHG: rebuild sites with missing sockets (migrations)
HEAD is now at 17520969 CHG: ignore reconfig errors (migrations)
[/usr/local/apnscp/lib/apnscpcore.php:97]
0. dl("igbinary.so")
1. include("/usr/local/apnscp/lib/apnscpcore.php")
fatal: igbinary extension not loadedUpdating to v3.2.37.1
Previous HEAD position was aa2aee55 FIX: set_timezone() asynchronously updates TZ (common)
HEAD is now at d849b1c2 FIX: default nullable (Sql)
fatal: igbinary extension not loadedJob for apnscp.service failed because the control process exited with error code.
fatal: igbinary extension not loadedUpdating to v3.2.37.2
error: Your local changes to the following files would be overwritten by checkout:
Please commit your changes or stash them before you switch branches.
error: The following untracked working tree files would be overwritten by checkout:
resources/playbooks/migrations/2023_05_26_160306_haproxy-update.yml
resources/playbooks/migrations/2023_06_02_200612-block-systemd.yml
Please move or remove them before you switch branches.
Aborting
fatal: igbinary extension not loadedUpgrade requested, but old = new (d849b1c2533fcf7033e6a8dc10f5c4f9ca8691f9)
