Best practice to upgrade HAProxy ?
Hi,
Running latest ApisCP on Rocky 10.1
I have a usecase where i need HAProxy 3.2 - ApisCP default ships 3.0
How can one upgrade without breaking future updates - or install 3.2 aside.
What is best and “supported” approach?
This is not openly supported nor by my edict - recommended. If someone would like to fund this endeavor, that’s great otherwise a shift to Envoy is best but again - capped at time.
Ok I assume you are commenting the dual versions option.
How about upgrading the existing version to latest - a pre-compiled or from source, and somehow tell apiscp not to change it back or somewhere in yaml to respect/use the newer version?
Envoy? No thanks. :slight_smile:
See Email server SSL cert mismatch - #2 by msaladna
Discussed ad nauseam here and on Discord. There is no future with haproxy.
