monit keeps spamming errors and fixes for postfix, and status monitors are reporting port 25 as non-working.
[web2] postfix
alert - failed protocol test [SMTP] at [localhost]:25 [TCP/IP] -- Error receiving data from the mailserver -- Resource temporarily unavailable
[web2] postfix
alert - connection succeeded to [localhost]:25 [TCP/IP]
Service appears to be up and working, but I found this in maillog:
Nov 14 20:10:44 web2 postfix/tlsmgr[1269730]: warning: dict_proxy_sequence: service proxywrite: Application error
Nov 14 20:10:44 web2 postfix/postscreen[1377623]: warning: dict_proxy_lookup: service proxywrite: Connection reset by peer
Nov 14 20:10:44 web2 postfix/master[2514]: warning: process /usr/libexec/postfix/proxymap pid 1378868 killed by signal 6
Nov 14 20:10:45 web2 postfix/proxymap[1378875]: panic: dict_db_sequence: no cursor
Nov 14 20:10:46 web2 postfix/postscreen[1377623]: warning: dict_proxy_lookup: service proxywrite: Connection reset by peer
Nov 14 20:10:46 web2 postfix/tlsmgr[1269730]: warning: dict_proxy_sequence: service proxywrite: Application error
Nov 14 20:10:46 web2 postfix/master[2514]: warning: process /usr/libexec/postfix/proxymap pid 1378875 killed by signal 6
Nov 14 20:10:46 web2 postfix/master[2514]: warning: /usr/libexec/postfix/proxymap: bad command startup -- throttling
Nov 14 20:10:50 web2 postfix/master[2514]: warning: master_wakeup_timer_event: service tlsmgr(private/tlsmgr): Resource temporarily unavailable
Nov 14 20:10:52 web2 postfix/postscreen[1377623]: fatal: watchdog timeout
Nov 14 20:10:53 web2 postfix/master[2514]: warning: process /usr/libexec/postfix/postscreen pid 1377623 exit status 1
Tests
ran upcp
restarted apiscpservice
restarted postfixservice
restarted haproxyservice
restarted server itself
[root@web2 ~]# cpcmd misc:cp-version
revision: 3ec2e7884c258580fa707cfe827a4269861007c6
timestamp: 1730519492
ver_patch: 45
[root@web2 ~]# uname -r
5.4.285-1.el8.elrepo.x86_64
