I have been trying to do some security hardening on a new system, and I’ve come across a somewhat concerning “feature” of the upcp process.
An important security tenant is to reduce the attack surface on the server, and one important thing to do is to lock down the ssh port.
I do this by adding firewall rules into the pre and post chains to allow access from a defined set of authorized IPs and the in the post chain drop all ssh packets. This also relies on deleting the access to port 22 in the normal allow chain that is added by default.
It turns out that after running “upcp -sb” the default allow port 22 rule is quietly added back negating the IP authorizations.
This is not great, but what I want to know is when does the system run “upcp” by itself? Is this done on a daily basis, and if so is there a way to tun it off so that it can be manually run when needed under manual control?
