2024-03-10 23:26:36,970 p=4608 u=root n=dnf.[fork.5467] | repo: using cache for: pgdg-common
2024-03-10 23:26:36,981 p=4608 u=root n=dnf.[fork.5467] | pgdg-common: using metadata from Wed 06 Mar 2024 12:50:21 PM CET.
2024-03-10 23:26:36,982 p=4608 u=root n=dnf.[fork.5467] | repo: using cache for: pgdg13
2024-03-10 23:26:36,983 p=4608 u=root n=dnf.[fork.5467] | pgdg13: using metadata from Tue 05 Mar 2024 02:29:13 PM CET.
2024-03-10 23:26:36,983 p=4608 u=root n=dnf.[fork.5467] | Last metadata expiration check: 0:01:35 ago on Sun 10 Mar 2024 11:25:01 PM CET.
2024-03-10 23:26:37,360 p=4608 u=root n=dnf.[fork.5467] | timer: sack setup: 719 ms
2024-03-10 23:26:37,393 p=4608 u=root n=dnf.[fork.5467] | timer: depsolve: 15 ms
2024-03-10 23:26:37,399 p=4602 u=root n=ansible | fatal: [localhost]: FAILED! => {"attempts": 2, "changed": false, "failures": [], "msg": "Depsolve Error occured: \n Problem: cannot install both httpd-2:2.4.58-2.apnscp.x86_64 from apnscp-updates and httpd-2:2.4.43-1.apnscp.x86_64 from apnscp\n - cannot install the best update candidate for package mod_http2-1.15.7-8.module+el8.9.0+1370+89cc8ad5.3.x86_64\n - cannot install the best update candidate for package httpd-2.4.37-62.module+el8.9.0+1436+2b7d5021.x86_64", "rc": 1, "results": []}
2024-03-10 23:26:37,400 p=4602 u=root n=ansible | PLAY RECAP *********************************************************************
2024-03-10 23:26:37,400 p=4602 u=root n=ansible | localhost : ok=113 changed=0 unreachable=0 failed=1 skipped=65 rescued=0 ignored=0
fresh install of Rocky 8
Dedicated server / bare metal
