I want to create a redis instance for Nextcloud (Transaction Locking)
I try to follow this instructions:
https://notes.apiscp.com/create-wp-redis-instance
Please provide detailed steps to reproduce the bug. Include any necessary code snippets, commands, or configuration files.
- Run Command
cpcmd -d site3 redis:create nextcloud-cache ‘[unixsocket:/var/www/redis.sock,unixsocketperm:0660]’
- Step 2
To check the availability i run the command:
cpcmd -d site3 misc:list-commands ‘redis:*’
redis:
- version
Command works like documented
got this error message:
apnscpFunctionInterceptor::check_permissions(): command
redis_create' does not exist. Did you meanredis_version’?
ApisCP version:
revision: 580c1ea0ec9b485bef8ff7072e0af6005166d48a
timestamp: 1696703086
ver_patch: 39
ver_pre: ‘’
Operating System:
4.18.0-277.el8.x86_64
cat /etc/redhat-release
CentOS Stream release 8
Additional Information:
Run the command for other sites too. All with the same result:
redis:
- version
Without SiteAdmin Context i got this:
cpcmd misc:list-commands ‘redis:*’
redis:
- key_memusage
- system_info
- version
