When curl updates (I am assuming when this is what triggers the issue), I get the following error from curl: [nexususer@server.tld ~]$ curl --version curl: symbol lookup error: curl: undefined symbol: curl_easy_ssls_export ,
To fix this issue, I have to remove ssh from the nexus account and re-add it via the gui. When this happens, SSL certificates also do no renew. The issue is that I have to do it for all accounts manually.
I have tried echo 2 > /proc/sys/vm/drop_caches and echo 3 > /proc/sys/vm/drop_caches
but that does not help along with systemctl reload fsmount as well as ldconfig.
Curl for root user is not effected.
When curl updates, it breaks curl for all nexus users. Please note that I am assuming that the update is causing this since
Please provide detailed steps to reproduce the bug. Include any necessary code snippets, commands, or configuration files.
- I caught the issue when my cron stops working and my ssl certs were not auto-renewing. SSL certs do renew if I run them manually from the nexus gui to renew
Describe what you expected to happen when the bug occurred.
Curl and cron working without needing to do the workaround .
Describe what actually happened when the bug occurred.
Described above.
Operating System: uname -r
revision: 4a49072c7df6ea8216258c5f8809f15a4aea4e76
timestamp: 1765698080
ver_pre: 35-g4a49072c7
uname -r
6.12.0-55.29.1.el10_0.x86_64
Running on RockyLinux 10.
Provide any additional information about the bug, such as error messages, logs, screenshots, or any other relevant details.
