Delta launches! apnscp's first experimental platform.
Delta has been launched! Delta is the first platform receiving a 7.5 designation and with all fractional platform releases is focused on experimental functionality. Delta’s primary goal is test apnscp 3.0, which is the first release of apnscp to be completely standalone without external dependencies, something that has become unmaintainable as platform complexity increases (for example, SSL configuration changes failing to reflect in HTTP configuration). Moreover all platform customizations are provided in RPM form (yum.apiscp.com) or through Ansible playbooks facilitating an easy process to produce the platform consistently.
This is a companion discussion topic for the original entry at https://hq.apiscp.com/delta-the-first-experimental-platform-built-on-apnscp/
