Fresh ApisCP install on Rocky Linux with OpenSSH 9.9p1. The embedded terminal (Dev → Terminal) loops on password and never authenticates for virtual users. SSH works fine for the admin account.
No custom configuration changes have been made. I thought it was my custom config previously so i restored from backups, it still didnt work, so ive just reinstalled Apiscp from fresh bootstrapper on another VM and getting the same issue.
- Fresh ApisCP install on Rocky Linux
- Create a hosted account
- Log into panel as that account
- Go to Dev → Terminal
- Enter password — loops indefinitely and eventually shows Permission denied
Terminal authenticates successfully, but can log into portal with ‘MyUserName’
Loops none stop. See below:
server1 login: ‘MyUserName’#krlit.co.uk
‘MyUserName’#krlit.co.uk@server1.krlit.co.uk’s password:
‘MyUserName’#krlit.co.uk@server1.krlit.co.uk: Permission denied (publickey,gssapi-keyex,gssapi-with-mic,password).
Session closed.
ApisCP version:
revision: 5fc4f3b861b34ce1aa8ebf09c7b7b6ecb1a68e29
timestamp: 1780436897
ver_pre: 5fc4f3b86
Operating System:
5.14.0-687.12.1.el9_8.x86_64
Admin SSH access works fine using putty to ssh, no blocked IP’s. Got Opnsense firewall and apiscp hosted on proxmox vm if that helps.
