One of my web application gets below error.
“Syntax error or access violation: 1104 The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET MAX_JOIN_SIZE=# if the SELECT is okay.”
Apparently it runs a query which requires processing large amount of data. I checked in mysql MAX_JOIN_SIZE is 5,000,000 instead of default value which is 18446744073709551615
I tried to increase value from phpmyadmin, but it gives error I need at least one super priviledges. I don’t understand how can I fix this.
Can you please explain how can I fix this?
Thanks
This was addressed over community chat, but for those searching there’s a 5 million record limit to prevent resource monopolization by a busted query. Rationale being 5,000,000 x 100 byte records coming together in a join isn’t encountered very often and symptomatic of a bad query.
You can disable this safety check by adding the following to /root/apnscp-vars-runtime.yml
then running upcp -sb mysql/install
mysql_custom_config:
max_join_size: -1
Or to override it manually, add to any file lexicographically higher than apnscp.cnf in /etc/my.cnf.d
[server]
max_join_size=-1
Then restart the service, systemctl restart mysql
Be sure to assign a category to posts so they get relayed to the chat!
