I am unable to install APISCP Successfully.
- This is the command I generated using your Apiscp Customizer
curl https://raw.githubusercontent.com/apisnetworks/apiscp-bootstrapper/master/bootstrap.sh | bash -s - -s use_robust_dns='true' -s always_permit_panel_login='true' -s php_install_ioncube='true' -s dns_default_provider='null' -s whitelist_ip='[REDACTED]' -s system_php_version='8.2' -s pgsql_version='15' -s spamfilter='rspamd' -s apnscp_admin_user='admin' -s apnscp_admin_email='[REDACTED]' -s mariadb_version='10.11' -s system_hostname='[REDACTED]' - This was on a 1.5 GB RAM Ryzen VPS. I have updated
limit_memory_2gbto 1300 in root/apnscp-vars.yml for install to continue
For Apiscp to install successfully
TASK [mail/rspamd : Install rspamd RPM] *******************************************************************************************************************************************************
FAILED - RETRYING: Install rspamd RPM (2 retries left).
FAILED - RETRYING: Install rspamd RPM (1 retries left).
attempts: 2
msg: Failed to validate GPG signature for rspamd-3.7.3-1.el8.x86_64
PLAY RECAP ************************************************************************************************************************************************************************************
localhost : ok=1305 changed=28 unreachable=0 failed=1 skipped=667 rescued=0 ignored=0
ERROR : Util_Process::formatDataCallProc(): cd: fatal: detected dubious ownership in repository at '/usr/local/apnscp'
Operating System: uname -r
[root@almalinux-8 playbooks]# uname -r
4.18.0-240.15.1.el8_3.x86_64
This was on a fresh almalinux 8
Processor : AMD Ryzen 9 7950X 16-Core Processor
CPU cores : 1 @ 4499.984 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM : 1.3 GiB
Swap : 1024.0 MiB
Disk : 28.5 GiB
Distro : AlmaLinux 8.8 (Sapphire Caracal)
Kernel : 4.18.0-240.15.1.el8_3.x86_64
VM Type : KVM
IPv4/IPv6 : ✔ Online / ❌ Offline
