I’m installing on a fresh server with Almalinux 8 and the ansible playbook command keeps failing on the mariadb installation step
TASK [Install MariaDB] ***************************************************************************************************************************************
TASK [common : Edit /etc/yum.repos.d/mariadb.repo] ***********************************************************************************************************
ok: [localhost] => (item=Set mariadb => name = MariaDB)
changed: [localhost] => (item=Set mariadb => baseurl = http://yum.mariadb.org/11.4/rhel$releasever-amd64)
ok: [localhost] => (item=Set mariadb => gpgkey = https://yum.mariadb.org/RPM-GPG-KEY-MariaDB)
ok: [localhost] => (item=Set mariadb => gpgcheck = 1)
TASK [packages/install : Install MariaDB 10.6+ prereqs] ******************************************************************************************************
failures:
- No package libpmem available.
msg: |-
Depsolve Error occurred:
Problem: cannot install the best candidate for the job
- package galera-4-26.4.19-1.el8.x86_64 from mariadb does not have a compatible architecture
- nothing provides ld-linux-x86-64.so.2()(64bit) needed by galera-4-26.4.19-1.el8.x86_64 from mariadb
- nothing provides ld-linux-x86-64.so.2(GLIBC_2.3)(64bit) needed by galera-4-26.4.19-1.el8.x86_64 from mariadb
- nothing provides libm.so.6(GLIBC_2.2.5)(64bit) needed by galera-4-26.4.19-1.el8.x86_64 from mariadb
- nothing provides libpthread.so.0(GLIBC_2.2.5)(64bit) needed by galera-4-26.4.19-1.el8.x86_64 from mariadb
- nothing provides libpthread.so.0(GLIBC_2.3.2)(64bit) needed by galera-4-26.4.19-1.el8.x86_64 from mariadb
- nothing provides libpthread.so.0(GLIBC_2.3.3)(64bit) needed by galera-4-26.4.19-1.el8.x86_64 from mariadb
rc: 1
results: []
PLAY RECAP ***************************************************************************************************************************************************
localhost : ok=108 changed=1 unreachable=0 failed=1 skipped=64 rescued=0 ignored=0
When I execute yum install libpmem I get the error below
ApisCP Packages for CentOS Linux 8 - aarch64 435 B/s | 521 B 00:01
Errors during downloading metadata for repository 'apnscp':
- Status code: 402 for https://yum.apiscp.com/os/8/aarch64/repodata/repomd.xml (IP: 45.32.193.57)
Error: Failed to download metadata for repo 'apnscp': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
ApisCP Package Updates for CentOS Linux 8 - aarch64 582 B/s | 521 B 00:00
Errors during downloading metadata for repository 'apnscp-updates':
- Status code: 402 for https://yum.apiscp.com/updates/8/aarch64/repodata/repomd.xml (IP: 45.32.193.57)
Error: Failed to download metadata for repo 'apnscp-updates': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried
Ignoring repositories: apnscp, apnscp-updates
Last metadata expiration check: 0:11:52 ago on Fri 01 Nov 2024 04:08:35 PM UTC.
No match for argument: libpmem
Error: Unable to find a match: libpmem
