I bought a license, did a fresh install on a fresh Alma Linux VM, failed=0, cloudflare enabled and confirmed working (except for apex record bug) and domain added. I submitted a Wordpress install and it failed with the following:
Detailed above. Error:
TypeError: Symfony\Component\Yaml\Yaml::parse(): Argument #1 ($input) must be of type string, bool given, called in /usr/local/apnscp/lib/Module/Support/Webapps/App/Type/Wordpress/Wpcli.php on line 78 and defined in /usr/local/apnscp/vendor/symfony/yaml/Yaml.php:76
Stack trace: #0 /usr/local/apnscp/lib/Module/Support/Webapps/App/Type/Wordpress/Wpcli.php(78): Symfony\Component\Yaml\Yaml::parse(false)
#1 /usr/local/apnscp/lib/Module/Support/Webapps/App/Type/Wordpress/module.php(175): Module\Support\Webapps\App\Type\Wordpress\Wpcli->setConfiguration(Array) #2 /usr/local/apnscp/lib/Module/Skeleton/Standard.php(145): Wordpress_Module->install(‘onninth.com’, ‘’, Array)
Wordpress would install successfully
Wordpress install failed/hung
revision: c19318e239642aeb7179ef951062fdc59f2e5c30
timestamp: 1729625863
ver_pre: c19318e23
Operating System:
4.18.0-553.22.1.el8_10.x86_64
All OOTB
What do the following commands report?
cpcmd -d onninth.com file:exists '~/.wp-cli/config.yml'
cpcmd -d onninth.com file:file-get-contents '~/.wp-cli/config.yml'
And anything in /usr/local/apnscp/storage/logs/start.log that would reference that function? Alternatively, you can mail me the log at matt@apisnetworks.com
Smells like a transient error. I’m not able to reproduce it. Any chance a subsequent install fails as well?
[root@cpanel ~]# cpcmd -d onninth.com file:exists ‘~/.wp-cli/config.yml’
[root@cpanel ~]# cpcmd -d onninth.com file:file-get-contents ‘~/.wp-cli/config.yml’
ERROR : apnscpFunctionInterceptor::check_permissions(): command file_file_get_contents' does not exist. Did you mean file_get_file_contents’?
**** 0. Error_Reporter::add_error(“command %(target)s' does not exist. Did you mean %(suggest)s’?”, [[target:“file_file_get_contents”, suggest:“file_get_file_contents”]])****
**** [/usr/local/apnscp/lib/log_wrapper.php:72]****
**** 1. error(“command %(target)s' does not exist. Did you mean %(suggest)s’?”, [target:“file_file_get_contents”, suggest:“file_get_file_contents”])****
**** [/usr/local/apnscp/lib/apnscpfunction.php:1025]****
** 2. apnscpFunctionInterceptor->check_permissions(“file”, “file_get_contents”)**
** [/usr/local/apnscp/lib/apnscpfunction.php:946]**
** 3. apnscpFunctionInterceptor->call(“file_file_get_contents”, [“~/.wp-cli/config.yml”])**
** [/usr/local/apnscp/lib/CLI/cmd.php:55]**
** 4. CLI__call(“file_file_get_contents”, [“~/.wp-cli/config.yml”])**
** [/usr/local/apnscp/lib/CLI/cmd.php:574]**
** 5. CLI\main()**
** [/usr/local/apnscp/bin/cmd:7]**
MESSAGE SUMMARY
Reporter level: ERROR
ERROR: apnscpFunctionInterceptor::check_permissions(): command file_file_get_contents' does not exist. Did you mean file_get_file_contents’?
Emailed you the start.log file as well.
/No Idea why some of the text is bold and larger…?
Check with the latest code by running upcp.
It may be linked back to the effective/actual UID checks corrected a few days ago that I saw manifest in plugin updates with multiPHP.
Funny you say that. I was curious if something went hay-wire during the installation so I ran a upcp and got: update=46 failed=0
