Error
./artisan opcenter:plan --new Economy
(ArgumentError) EXCEPTION: Plan Economy does not exist
[/usr/local/apnscp/lib/Lararia/Console/Commands/OpcenterPlanCommand.php:115]
0. Lararia\Console\Commands\OpcenterPlanCommand->handle()
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:36]
1. Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/Util.php:37]
2. Illuminate\Container\Util::unwrapIfClosure()
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:93]
3. Illuminate\Container\BoundMethod::callBoundMethod(Lararia\Application, [Lararia\Console\Commands\OpcenterPlanCommand, "handle"], )
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:37]
4. Illuminate\Container\BoundMethod::call(Lararia\Application, [Lararia\Console\Commands\OpcenterPlanCommand, "handle"], null)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/Container.php:590]
5. Illuminate\Container\Container->call([Lararia\Console\Commands\OpcenterPlanCommand, "handle"])
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Command.php:134]
6. Illuminate\Console\Command->execute(Symfony\Component\Console\Input\ArgvInput, Illuminate\Console\OutputStyle)
[/usr/local/apnscp/vendor/symfony/console/Command/Command.php:255]
7. Symfony\Component\Console\Command\Command->run(Symfony\Component\Console\Input\ArgvInput, Illuminate\Console\OutputStyle)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Command.php:121]
8. Illuminate\Console\Command->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/vendor/symfony/console/Application.php:1021]
9. Symfony\Component\Console\Application->doRunCommand(Lararia\Console\Commands\OpcenterPlanCommand, Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/vendor/symfony/console/Application.php:275]
10. Symfony\Component\Console\Application->doRun(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/vendor/symfony/console/Application.php:149]
11. Symfony\Component\Console\Application->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Application.php:93]
12. Illuminate\Console\Application->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:131]
13. Illuminate\Foundation\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/lib/Lararia/Console/Kernel.php:31]
14. Lararia\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/artisan:69]
