I’ve never been able to send mail from my sites.
Trying to set them up via config mail-enable-dkim-signing I get a popup Opcenter\Admin\Settings\Mail\DkimSigning::set(): rspamd must be enabled.
When I go to config mail – rspamd-piggyback it says it is enabled.
Not sure how mail – rspamd-piggyback shows as enabled but rspmad is not installed.
I tried to do it manually starting with a command I found on Google:
curl -sSL https://rspamd.com/rpm-stable/centos-8/rspamd.repo | sudo tee /etc/yum.repos.d/rspamd.repo
But it fails with a “sudo a password is required” error. If I’m already operating as root using sudo I have no idea how to add a password to the command when it doesn’t prompt for one.
After installation I should do -
sudo dnf install rspamd redis
sudo systemctl enable --now redis
sudo systemctl enable --now rspamd
Which I assume is what your cpcmd scope:set mail.rspamd-piggyback true should have done.
I just did your upcp command but rspamd is still not installed.
I did find that the su password malfunction was caused by 000 permissions on /etc/shadow. Suggested fix was chmod 0400 which I’ve done but su still has a spack attack. Running the latest version of Rocky Linux 8
Do I need to restart the server as exit / restart session makes no difference?
Restarted server and keep getting this -
[root@host ~]# sudo dnf upgrade -y
sudo: PAM account management error: Authentication service cannot retrieve authentication info
sudo: a password is required
Tried to send an email from cyberhorse.com.au to Gmail and it got refused due to no DKIM even though I enabled it successfully. Does it take time to kick in as Gmail has rejected such emails in the past? Also where do I enable SPF?
The final field in the SOA record is how long an NXDOMAIN result is held in cache. Wikipedia has a great entry on all these fields and how they work.
;; ANSWER SECTION:
cyberhorse.com.au. 0 IN SOA chloe.ns.cloudflare.com. dns.cloudflare.com. 2402301024 10000 2400 604800 1800
Based upon that result, it’s at least 1800 seconds. MTAs may implement their own discretionary TTLs.
I don’t know. I don’t run Google. You’re getting an “error” but that’s very imprecise.
Have you tried soliciting your DMARC record through a third-party that specializes in it? MXToolbox is a good start. Google Search is a good follow up, but bear in mind I do not run it.
Problem solved. Both DKIM and SPF were set up to reject all mail so I couldn’t send anything to anybody. Must have been a default setting. Stupid me thought that the records just needed to be present without looking at what they were telling mail recipients to do. Once I fixed that Gmail and Hotmail were happy to get emails from my domains. Thanks for your help.
