Thanks. This script was running several minutes and spammed the terminal but now everything is cleaned up in /home/. Just site1 is remaining for some reason.
Maybe a bit too much has been deleted now. upcp --reset gives some error:
TASK [mail/configure-postfix : {{ item.value | default(false, true) | ternary('Set', 'Remove') }} {{item.key}} => {{ item.value}} in {{ config_file }}] ***
failed: [localhost] (item=Set message_size_limit => 100000000) => changed=false
ansible_loop_var: item
item:
key: message_size_limit
value: '100000000'
msg: Destination /home/virtual/FILESYSTEMTEMPLATE/siteinfo//etc/postfix/main.cf does not exist !
rc: 257
PLAY RECAP *********************************************************************
localhost : ok=7 changed=0 unreachable=0 failed=1 skipped=3 rescued=0 ignored=0
STDERR:
[/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:211]
0. Lararia\Database\Migrations\PlatformMigrator->runMigration("2024_11_14_162936_platform-tweaks", "up", [step:true])
[/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:128]
1. Lararia\Database\Migrations\PlatformMigrator->runUp("/usr/local/apnscp/resources/playbooks/migrations/2024_11_14_162936_platform-tweaks.yml", 35, false)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:165]
2. Illuminate\Database\Migrations\Migrator->runPending(["/usr/local/apnscp/resources/playbooks/migrations/2024_11_14_162936_platform-tweaks.yml"], [pretend:false, step:0, rollback:false, ff:false])
[/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:92]
3. Lararia\Database\Migrations\PlatformMigrator->runPending(["/usr/local/apnscp/resources/playbooks/migrations/2024_11_14_162936_platform-tweaks.yml"], [pretend:false, step:0, rollback:false, ff:false])
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:110]
4. Illuminate\Database\Migrations\Migrator->run(["/usr/local/apnscp/resources/playbooks/migrations"], [pretend:false, step:0, rollback:false, ff:false])
[/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:40]
5. Lararia\Database\Migrations\PlatformMigrator->run(["/usr/local/apnscp/resources/playbooks/migrations"], [pretend:false, step:0, rollback:false, ff:false])
[/usr/local/apnscp/lib/Lararia/Console/Commands/PlatformMigration.php:76]
6. Lararia\Console\Commands\PlatformMigration->handle()
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:36]
7. Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/Util.php:37]
8. Illuminate\Container\Util::unwrapIfClosure()
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:93]
9. Illuminate\Container\BoundMethod::callBoundMethod(Lararia\Application, [], [Lararia\Console\Commands\PlatformMigration, "handle"], )
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:37]
10. Illuminate\Container\BoundMethod::call(Lararia\Application, [], [Lararia\Console\Commands\PlatformMigration, "handle"], null)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/Container.php:590]
11. Illuminate\Container\Container->call([Lararia\Console\Commands\PlatformMigration, "handle"])
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Command.php:134]
12. Illuminate\Console\Command->execute(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
[/usr/local/apnscp/vendor/symfony/console/Command/Command.php:255]
13. Symfony\Component\Console\Command\Command->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Command.php:121]
14. Illuminate\Console\Command->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
[/usr/local/apnscp/vendor/symfony/console/Application.php:1021]
15. Symfony\Component\Console\Application->doRunCommand(Lararia\Console\Commands\PlatformMigration, Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
[/usr/local/apnscp/vendor/symfony/console/Application.php:275]
16. Symfony\Component\Console\Application->doRun(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
[/usr/local/apnscp/vendor/symfony/console/Application.php:149]
17. Symfony\Component\Console\Application->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Application.php:93]
18. Illuminate\Console\Application->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Application.php:185]
19. Illuminate\Console\Application->call("migrate:platform", [--force:true, --pretend:false], Illuminate\Console\OutputStyle)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:273]
20. Illuminate\Foundation\Console\Kernel->call("migrate:platform", [--force:true, --pretend:false], Illuminate\Console\OutputStyle)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php:261]
21. Illuminate\Support\Facades\Facade::__callStatic("call", ["migrate:platform", [[--force:true, --pretend:false], Illuminate\Console\OutputStyle]])
[/usr/local/apnscp/lib/Lararia/Console/Commands/Migrate.php:55]
22. Lararia\Console\Commands\Migrate->handle()
23. Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
24. Illuminate\Container\Util::unwrapIfClosure()
25. Illuminate\Container\BoundMethod::callBoundMethod(Lararia\Application, [], [Lararia\Console\Commands\Migrate, "handle"], )
26. Illuminate\Container\BoundMethod::call(Lararia\Application, [], [Lararia\Console\Commands\Migrate, "handle"], null)
27. Illuminate\Container\Container->call([Lararia\Console\Commands\Migrate, "handle"])
28. Illuminate\Console\Command->execute(Symfony\Component\Console\Input\ArgvInput, Illuminate\Console\OutputStyle)
29. Symfony\Component\Console\Command\Command->run(Symfony\Component\Console\Input\ArgvInput, Illuminate\Console\OutputStyle)
30. Illuminate\Console\Command->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
31. Symfony\Component\Console\Application->doRunCommand(Lararia\Console\Commands\Migrate, Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
32. Symfony\Component\Console\Application->doRun(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
33. Symfony\Component\Console\Application->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
34. Illuminate\Console\Application->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:131]
35. Illuminate\Foundation\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/lib/Lararia/Console/Kernel.php:31]
36. Lararia\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/artisan:69]
The entire postfix folder is missing in /home/virtual/FILESYSTEMTEMPLATE/siteinfo//etc/ but just on this machine.
