Trying to Install ApisCP on the latest Rocky Linux.,
I got this error.
[root@netserver playbooks]# grep -m1 failed=1 -B20 /root/apnscp-bootstrapper.log
2022-07-14 02:17:52,335 p=10354 u=cache n=ansible | changed: [localhost]
2022-07-14 02:17:52,356 p=10354 u=cache n=ansible | TASK [packages/install : Loa d packages from os.yml] ****************************
2022-07-14 02:17:52,386 p=10354 u=cache n=ansible | ok: [localhost]
2022-07-14 02:17:52,453 p=10354 u=cache n=ansible | TASK [packages/install : Add RPM channel OS] ***********************************
2022-07-14 02:17:52,514 p=10354 u=cache n=ansible | skipping: [localhost]
2022-07-14 02:17:52,579 p=10354 u=cache n=ansible | TASK [packages/install : Imp ort RPM key OS] ************************************
2022-07-14 02:17:52,640 p=10354 u=cache n=ansible | skipping: [localhost]
2022-07-14 02:17:52,660 p=10354 u=cache n=ansible | TASK [packages/install : Ins tall packages] *************************************
2022-07-14 02:18:56,887 p=10354 u=cache n=ansible | fatal: [localhost]: FAILED! => changed=false
attempts: 2
failures: []
msg: |-
Unknown Error occured: Transaction test error:
file /usr/lib64/.libgnutls.so.30.28.2.hmac from install of gnutls-devel-3. 6.16-4.el8.x86_64 conflicts with file from package gnutls-3.6.16-4.el8.x86_64
rc: 1
results: []
2022-07-14 02:18:56,890 p=10354 u=cache n=ansible | RUNNING HANDLER [common : no op] ************************************************
2022-07-14 02:18:56,890 p=10354 u=cache n=ansible | RUNNING HANDLER [filesystem/ make-mounts : Reload tmp.mount] ********************
2022-07-14 02:18:56,890 p=10354 u=cache n=ansible | RUNNING HANDLER [filesystem/ make-mounts : Restart polkitd] *********************
2022-07-14 02:18:56,892 p=10354 u=cache n=ansible | PLAY RECAP ***************** ****************************************************
2022-07-14 02:18:56,892 p=10354 u=cache n=ansible | localhost : ok=126 changed=42 unreachable=0 failed=1 skipped=67 rescued=0 ign ored=0
