Installation hung
Hi,
Installation (on fresh Rocky 8) has hang here:
2024-08-23 15:52:11,975 p=465466 u=root n=ansible | TASK [apnscp/notify-installed : Clean RPM cache] *******************************
2024-08-23 15:52:12,292 p=465466 u=root n=ansible | changed: [localhost]
2024-08-23 15:52:12,306 p=465466 u=root n=ansible | TASK [apnscp/notify-installed : Flag install completed] ************************
2024-08-23 15:52:12,357 p=465466 u=root n=ansible | changed: [localhost]
2024-08-23 15:52:12,358 p=465466 u=root n=ansible | RUNNING HANDLER [common : Drop filesystem caches] ******************************
2024-08-23 15:52:13,282 p=465466 u=root n=ansible | changed: [localhost]
2024-08-23 15:52:13,283 p=465466 u=root n=ansible | RUNNING HANDLER [common : Restart apnscp] **************************************
2024-08-23 15:52:13,780 p=465466 u=root n=ansible | changed: [localhost]
2024-08-23 15:52:13,784 p=465466 u=root n=ansible | PLAY RECAP *********************************************************************
2024-08-23 15:52:13,784 p=465466 u=root n=ansible | localhost                  : ok=1702 changed=194  unreachable=0    failed=0    skipped=832  rescued=0    ignored=1
What should i do?
Thanks
Alex
It’s finished. See Installation > Provisioning.
