I am sorry i feel like a broken record here but i have not been able to get invoice ninja to install.
What i see from the UI
I create a subdomain example in this case: sub.domain.org using Web → Subdomains
It creates a DNS entry, the page loads with no ssl. no problem.
Then when i go to Web Apps and select the domain (shows thumbnail) then click Invoice Ninja
Empty Folder, Enable SSL, enable auto updates
I get an email saying the install is successful, but when i try to access the page it is not able to resolve the DNS
I went into the DNS section and the DNS is gone, when i re-add the DNS it shows a blank page with the following details in the source screen.
<!DOCTYPE html>
<html data-report-errors="1" data-rc="" data-user-agent="Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:144.0) Gecko/20100101 Firefox/144.0" data-login="">
<head>
<!-- Source: https://github.com/invoiceninja/invoiceninja -->
<!-- Version: 5.12.28 -->
<meta charset="UTF-8">
<title>Invoice Ninja</title>
<meta name="google-signin-client_id" content="">
</head>
<body class="h-full">
<noscript>You need to enable JavaScript to run this app.</noscript>
<div id="root"></div>
</body>
If you are reading this, there is a fair change that the react application has not loaded for you. There are a couple of solutions:
1. Download the release file from https://github.com/invoiceninja/invoiceninja and overwrite your current installation.
2. Switch back to the Flutter application by editing the database, you can do this with the following SQL
UPDATE accounts SET
set_react_as_default_ap = 0;
</html>
NOW when i create a new subdomain t-sub.domain.org, delete the index file, and go back to the Web Apps
Select invoice ninja, turn off all the check boxes and select Major and no autoupdates, no ssl, and no emptying directories
i still get a deleted DNS and when readded a white screen
Please provide detailed steps to reproduce the bug. Include any necessary code snippets, commands, or configuration files.
Step 1
create sub domain -
Step 2
go to web apps -
Step 3
select invoice ninja, then hit install -
Step 4
click link in the email when the success message comes in and see DNS error -
step 5
readd dns -
step 6
see blank screen
load a welcome screen and roll out the red carpet
blank screen no error
Operating System: uname -r
ver_pre: 21-g59a2ba9bc
PHP on the account is 8.4
MariaDB 11.6.2
Provide any additional information about the bug, such as error messages, logs, screenshots, or any other relevant details.
on this release
