-- Unit apnscp.service has begun starting up.
May 02 00:43:51 <servername> systemd[1]: apnscp.service: Supervising process 19639 which is not our child. We'll >
May 02 00:43:51 <servername> systemd[1]: apnscp.service: Main process exited, code=exited, status=255/n/a
May 02 00:43:51 <servername> httpd[19641]: httpd: Syntax error on line 82 of /usr/local/apnscp/config/httpd.conf:>
May 02 00:43:51 <servername> systemd[1]: apnscp.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- Defined-By: systemd
-- Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- The unit apnscp.service has entered the 'failed' state with result 'exit-code'.
May 02 00:43:51 <servername> systemd[1]: Failed to start ApisCP backend service.
-- Subject: Unit apnscp.service has failed
-- Unit apnscp.service has failed.
-- The result is failed.
systemctl restart apiscp
Job for apnscp.service failed because the control process exited with error code .
See "systemctl status apnscp.service" and "journalctl -xe" for details.
journalctl -xe
May 02 00:58:20 <servername> auth[18016]: auth worker: PASSV: pam_unix(imap:auth): authentication failure; logname= uid=0 e>
May 02 00:58:24 <servername> auth[18097]: auth worker: PASSV: pam_listfile(imap:auth): Couldn't open /etc/imap.pamlist
May 02 00:58:24 <servername> auth[18097]: auth worker: PASSV: pam_unix(imap:auth): check pass; user unknown
May 02 00:58:24 <servername> auth[18097]: auth worker: PASSV: pam_unix(imap:auth): authentication failure; logname= uid=0 e>
May 02 00:58:29 <servername> dovecot[3749]: imap-login: Disconnected: Aborted login by logging out (auth failed, 2 attempts>
May 02 00:58:29 <servername> auth[18136]: auth worker: PASSV: pam_listfile(imap:auth): Couldn't open /etc/imap.pamlist
May 02 00:58:29 <servername> auth[18136]: auth worker: PASSV: pam_unix(imap:auth): check pass; user unknown
May 02 00:58:29 <servername> auth[18136]: auth worker: PASSV: pam_unix(imap:auth): authentication failure; logname= uid=0 e>
May 02 00:58:33 <servername> auth[18184]: auth worker: PASSV: pam_listfile(imap:auth): Couldn't open /etc/imap.pamlist
May 02 00:58:33 <servername> auth[18184]: auth worker: PASSV: pam_unix(imap:auth): check pass; user unknown
May 02 00:58:33 <servername> auth[18184]: auth worker: PASSV: pam_unix(imap:auth): authentication failure; logname= uid=0 e>
May 02 00:58:37 <servername> dovecot[3749]: imap-login: Disconnected: Aborted login by logging out (auth failed, 2 attempts>
May 02 00:58:37 <servername> auth[18226]: auth worker: PASSV: pam_listfile(imap:auth): Couldn't open /etc/imap.pamlist
May 02 00:58:37 <servername> auth[18226]: auth worker: PASSV: pam_unix(imap:auth): check pass; user unknown
./apnscpd -f restart
PHP Fatal error: Uncaught Error: Class "Error_Reporter" not found in /usr/local/apnscp/lib/log_wrapper.php:14
Stack trace:
#0 /usr/local/apnscp/lib/apnscpcore.php(35): include()
#1 /usr/local/apnscp/lib/lservice.php(25): include('/usr/local/apns...')
#2 {main}
thrown in /usr/local/apnscp/lib/log_wrapper.php on line 14
Stack trace:
#2 {main}
upcp --reset
fatal: not a git repository (or any of the parent directories): .git
Reasserting permissions
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr/local
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr/local/apnscp
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr/local/apnscp/bin
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr/local/apnscp/bin/apnscpd.bin
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr/local/apnscp/lib
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr/local/apnscp/lib/Opcenter
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr/local/apnscp/lib/Opcenter/License.php.bin
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr/local/apnscp/lib/Opcenter/Apnscp.php.bin
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr/local/apnscp/lib/Opcenter/System
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr/local/apnscp/lib/Opcenter/System/GenericSystemdService.php.bin
storage/cache/e5f3d606bb6f9d11efd827797f51f0ee/usr/local/apnscp/lib/apnscpfunction.php.bin
storage/tmp/agent-root
Stack trace:
#1 /usr/local/apnscp/artisan(19): include('/usr/local/apns...')
#2 {main}
You have new mail in /root/Mail
cd /usr/local/apnscp
rm -rf .git/{objects,refs}
git clone https://gitlab.com/apisnetworks/apnscp.git ../apnscp-2
Cloning into '../apnscp-2'...
remote: Enumerating objects: 66691, done.
remote: Counting objects: 100% (2819/2819), done.
remote: Compressing objects: 100% (1125/1125), done.
remote: Total 66691 (delta 1644), reused 2707 (delta 1586), pack-reused 63872 (from 1)
Receiving objects: 100% (66691/66691), 60.99 MiB | 61.96 MiB/s, done.
Resolving deltas: 100% (47317/47317), done.
cp -dpR ../apnscp-2/.git/{objects,refs} .git/
git fetch origin
upcp --reset
.git/objects
.git/objects/pack
.git/objects/pack/pack-772e37d34805d3ed99728898fecdb245d13221ae.pack
.git/objects/pack/pack-772e37d34805d3ed99728898fecdb245d13221ae.idx
.git/objects/info
.git/refs
.git/refs/heads
.git/refs/heads/master
.git/refs/tags
.git/refs/remotes
.git/refs/remotes/origin
.git/refs/remotes/origin/HEAD
Stack trace:
#2 {main}
HEAD is now at eb8903969 FIX: st_dev field data type is unsigned int (Opcenter\Filesystem) CHG: workaround for blkcg_iostat_update kernel panic (System\Cgroup)
Installing dependencies from lock file (including require-dev)
Verifying lock file contents can be installed on current platform.
Nothing to install, update or remove
Package swiftmailer/swiftmailer is abandoned, you should avoid using it. Use symfony/mailer instead.
Package symfony/debug is abandoned, you should avoid using it. Use symfony/error-handler instead.
Package true/punycode is abandoned, you should avoid using it. No replacement was suggested.
Generating autoload files
90 packages you are using are looking for funding.
Use the `composer fund` command to find out more!
Nothing to migrate.
Nothing to migrate.
