In the last days, weeks i recognized a raising storage usage of several Sites.
Which is not normal for these sites in this amount or short time range.
So i´ve checked what uses so much storage at these sites.
Each time it is “mod_pagespeed” under /var/cache.
In these folders there are PHP files stored, always the same, but each time with different query strings:
for example:
-rw------- 1 apache admin8 173 Nov 3 16:34 'addfav.php,3Fpid=1205,26referer=displayimage.php,3Falbum=2,26pid=1205,'
-rw------- 1 apache admin8 173 Nov 3 16:34 'addfav.php,3Fpid=1203,26referer=displayimage.php,3Falbum=2,26pid=1203,'
-rw------- 1 apache admin8 173 Nov 3 16:34 'addfav.php,3Fpid=1206,26referer=displayimage.php,3Falbum=2,26pid=1206,'
-rw------- 1 apache admin8 173 Nov 3 16:34 'addfav.php,3Fpid=1209,26referer=displayimage.php,3Falbum=2,26pid=1209,'
-rw------- 1 apache admin8 173 Nov 3 16:34 'addfav.php,3Fpid=1207,26referer=displayimage.php,3Falbum=2,26pid=1207,'
-rw------- 1 apache admin8 173 Nov 3 16:34 'addfav.php,3Fpid=1208,26referer=displayimage.php,3Falbum=2,26pid=1208,'
-rw------- 1 apache admin8 173 Nov 3 16:34 'addfav.php,3Fpid=1210,26referer=displayimage.php,3Falbum=2,26pid=1210,'
-rw------- 1 apache admin8 173 Nov 3 16:35 'addfav.php,3Fpid=1217,26referer=displayimage.php,3Falbum=2,26pid=1217,'
-rw------- 1 apache admin8 173 Nov 3 16:35 'addfav.php,3Fpid=1213,26referer=displayimage.php,3Falbum=2,26pid=1213,'
or
-rw------- 1 apache admin12 73K Nov 3 16:46 'style.php,3Fid=1,26lang=de,26sid=7a116708d87b8546b6dc5970ef66e794,'
-rw------- 1 apache admin12 73K Nov 3 16:46 'style.php,3Fid=1,26lang=de,26sid=ff6816ccc18fa0caa65f8889c9a525a0,'
-rw------- 1 apache admin12 73K Nov 3 16:46 'style.php,3Fid=1,26lang=de,26sid=4c1f3f7113e9610afdc2f14c10ae30b8,'
-rw------- 1 apache admin12 73K Nov 3 16:46 'style.php,3Fid=1,26lang=de,26sid=a5b9941c6567ecef7a59b963c27868ed,'
-rw------- 1 apache admin12 73K Nov 3 16:46 'style.php,3Fid=1,26lang=de,26sid=9222283a984ba6517bed89feebace6fe,'
-rw------- 1 apache admin12 73K Nov 3 16:46 'style.php,3Fid=1,26lang=de,26sid=875d32f1332e90dccc417017b795d431,'
-rw------- 1 apache admin12 73K Nov 3 16:46 'style.php,3Fid=1,26lang=de,26sid=cb59cf1b4e55c1f2740d4fd1b2a6a163,'
in the first case it is each time the addfav.php is requested with different Picture IDs.
In the second case, each time a different session id is used.
This fills up the available Storage very fast, and results in “DOS” because the sItes reach their quota limit.
My Apache Scope settings are:
cpcmd scope:get apache.cachetype
explicit
memory
I´m confused when apache.cache is set as “memory” why are there so many Files stored to disk?
Also i tried to disable apache.cache via
cpcmd scope:set apache.cache false
and run then an htrebuild and restart the Webserver.
But i didn´t recognized any changes. The Cache is still filled up with the same files and different Session IDs.
So it seems to me that this change has no effekt.
Maybe i missed something?!?
But the current mod_pagespeed default behavior doesn´t work for me.
