- What version of apnscp are you running?
cpcmd misc_cp_versioncpcmd doesn’t work but starting this month, so less than a week ago, the monthly routine finished without errors. I guess thus I’m on the latest current release. - Which version of RHEL or CentOS are you using? Rocky 8.10
- Can you reproduce this bug reliably? Provide steps. If not, provide steps to the best of your recollection.
Issueing any cpcmd command or artisan directly causes this error. I already tried upcp --reset but no success.
(Symfony\Component\Debug\Exception\FatalThrowableError) EXCEPTION: Illuminate\Config\Repository::__construct(): Argument #1 ($items) must be of type array, int given, called in /usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/LoadConfiguration.php on line 36
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Config/Repository.php:24]
0. Illuminate\Config\Repository->__construct(1)
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/LoadConfiguration.php:36]
1. Illuminate\Foundation\Bootstrap\LoadConfiguration->bootstrap(Lararia\Application, [])
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Application.php:219]
2. Illuminate\Foundation\Application->bootstrapWith(["Illuminate\Foundation\Bootstrap\LoadEnvironmentVariables", "Illuminate\Foundation\Bootstrap\LoadConfiguration", "Illuminate\Foundation\Bootstrap\HandleExceptions", "Illuminate\Foundation\Bootstrap\RegisterFacades", "Illuminate\Foundation\Bootstrap\SetRequestForConsole", "Illuminate\Foundation\Bootstrap\RegisterProviders", "Illuminate\Foundation\Bootstrap\BootProviders"])
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:320]
3. Illuminate\Foundation\Console\Kernel->bootstrap()
[/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:129]
4. Illuminate\Foundation\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/lib/Lararia/Console/Kernel.php:31]
5. Lararia\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
[/usr/local/apnscp/artisan:69]
