An MCP server will be coming next release, a rough cut at least. It uses the same authentication system as SOAP, which is to say disabling SOAP authentication will also disable MCP usage.
curl -H Auth-Key: xyz http://localhost:2082/mcp -d '{"jsonrpc":"2.0","id":3,"method":"tools/call","params":{"name":"common_whoami","arguments":{}}}'
{"jsonrpc":"2.0","id":3,"result":{"content":[{"type":"text","text":"\"admin\""}],"isError":false}}
What tools would you like to see? For example, “Install APP on DOMAIN using git repo Y” would add a domain to an account, then install the specified webapp with SSL enabled for that site while pulling down a git repo; all those features exist in the API.
Another idea would be monitoring service status/performance through DAPHNIE and/or Argos. Things that can be informative yet also cut down on needless repetition. The more that can be accomplished without logging into the UI is where I’d like to take idea.
