Migration was stalled more than 30 days due to unrelated issue now getting errors
Website is down (server:2083) and I cannot fix this:
[root@cpanel2 apnscp]# cpcmd
WARNING: socket_connect(): unable to connect [111]: Connection refused
[/usr/local/apnscp/lib/datastream.php:282]
0. socket_connect(Socket, “/usr/local/apnscp/storage/run/apnscp.sock”)
1. DataStream->connect()
[/usr/local/apnscp/lib/datastream.php:230]
2. DataStream->writeSocket()
[/usr/local/apnscp/lib/datastream.php:405]
3. DataStream->pipeline()
[/usr/local/apnscp/lib/datastream.php:394]
4. DataStream->query(“common_load_preferences”)
[/usr/local/apnscp/lib/Module/Skeleton/Standard.php:201]
5. Module\Skeleton\Standard->query(“common_load_preferences”)
[/usr/local/apnscp/lib/modules/common.php:868]
6. Common_Module->load_preferences()
[/usr/local/apnscp/lib/Module/Skeleton/Standard.php:146]
7. Module\Skeleton\Standard->_invoke(“load_preferences”, )
[/usr/local/apnscp/lib/apnscpfunction.php:996]
8. apnscpFunctionInterceptor->call(“common_load_preferences”, )
[/usr/local/apnscp/lib/apnscpfunction.php:936]
9. apnscpFunctionInterceptor->__call(“common_load_preferences”, )
[/usr/local/apnscp/lib/apnscpfunction.php:125]
10. apnscpFunctionInterceptor::factory(Auth_Info_User, [username:“youngblood”, domain:“”, level:8, site_id:0, group_id:983, user_id:984, id:“UcIAVIwRjfDVvkz3i2PXSYqYqYGBFPvs”, hotworker:null, language:“C”, ])
[/usr/local/apnscp/lib/Auth/CLI.php:238]
11. Auth_CLI->getInvoker()
[/usr/local/apnscp/lib/CLI/cmd.php:648]
12. CLI\cmd(“youngblood”, false, “”)
[/usr/local/apnscp/lib/CLI/cmd.php:466]
13. CLI\parse([verbose:0, interactive:0, raw:0, delimiter:“”, output:“auto”, input:“cli”, multimode:false, fd:1])
[/usr/local/apnscp/lib/CLI/cmd.php:511]
14. CLI\main()
[/usr/local/apnscp/bin/cmd:7]
14. CLI\main()
FATAL : fatal(): Control panel is peforming a regularly scheduled update. Please try again in a few minutes…
0. Error_Reporter::trigger_fatal(“Control panel is peforming a regularly scheduled update. Please try again in a few minutes…”, )
[/usr/local/apnscp/lib/log_wrapper.php:50]
1. fatal(“Control panel is peforming a regularly scheduled update. Please try again in a few minutes…”)
[/usr/local/apnscp/lib/datastream.php:289]
2. DataStream->connect()
3. DataStream->writeSocket()
4. DataStream->pipeline()
5. DataStream->query(“common_load_preferences”)
6. Module\Skeleton\Standard->query(“common_load_preferences”)
7. Common_Module->load_preferences()
8. Module\Skeleton\Standard->_invoke(“load_preferences”, )
9. apnscpFunctionInterceptor->call(“common_load_preferences”, )
10. apnscpFunctionInterceptor->__call(“common_load_preferences”, )
11. apnscpFunctionInterceptor::factory(Auth_Info_User, [username:“youngblood”, domain:“”, level:8, site_id:0, group_id:983, user_id:984, id:“UcIAVIwRjfDVvkz3i2PXSYqYqYGBFPvs”, hotworker:null, language:“C”, ])
12. Auth_CLI->getInvoker()
13. CLI\cmd(“youngblood”, false, “”)
14. CLI\parse([verbose:0, interactive:0, raw:0, delimiter:“”, output:“auto”, input:“cli”, multimode:false, fd:1])
15. CLI\main()
ERROR: fatal(): Control panel is peforming a regularly scheduled update. Please try again in a few minutes…
[root@cpanel2 apnscp]# ./bin/apnscpd -f
INFO : Frontend HTTP started with PID `4908’
ERROR : Opcenter\License::verify(): license expired on Tue, 03 Mar 2026 07:03:04 +0000 - visit my.apnscp.com to issue a new certificate
0B. Error_Reporter::add_error(“license expired on %s - visit my.apnscp.com to issue a new certificate”, [“Tue, 03 Mar 2026 07:03:04 +0000”])
[/usr/local/apnscp/lib/log_wrapper.php:72]
1B. error(“license expired on %s - visit my.apnscp.com to issue a new certificate”, “Tue, 03 Mar 2026 07:03:04 +0000”)
[/usr/local/apnscp/lib/Opcenter/License.php:353]
2B. Opcenter\License->verify()
[/usr/local/apnscp/lib/lservicelib.pht:557]
3B. ListenerService\Daemon->_verify()
[/usr/local/apnscp/lib/lservicelib.pht:521]
4B. ListenerService\Daemon->verify_license()
[/usr/local/apnscp/lib/lservicelib.pht:1012]
5B. ListenerService\Daemon->spawn()
[/usr/local/apnscp/lib/lservicelib.pht:998]
6B. ListenerService\Daemon->spawn_workers()
[/usr/local/apnscp/lib/lservicelib.pht:323]
7B. ListenerService\Daemon->start()
[/usr/local/apnscp/lib/lservicelib.pht:170]
8B. ListenerService\Daemon->__construct()
[/usr/local/apnscp/lib/lservicelib.pht:1466]
9B. ListenerService\Daemon::init()
[/usr/local/apnscp/lib/lservice.php:28]
ERROR : ListenerService\Daemon::verify_license(): failed to verify license
0B. Error_Reporter::add_error(“failed to verify license”, )
1B. error(“failed to verify license”)
[/usr/local/apnscp/lib/lservicelib.pht:526]
2B. ListenerService\Daemon->verify_license()
3B. ListenerService\Daemon->spawn()
4B. ListenerService\Daemon->spawn_workers()
5B. ListenerService\Daemon->start()
6B. ListenerService\Daemon->__construct()
7B. ListenerService\Daemon::init()
Killed
[root@cpanel2 apnscp]# /usr/local/apnscp/bin/cmd license:activate {KEY}
10. apnscpFunctionInterceptor::factory(Auth_Info_User, [username:“youngblood”, domain:“”, level:8, site_id:0, group_id:983, user_id:984, id:“pFBs5BT1vPkbJyD6DUYqqmXs8oS89p4b”, hotworker:null, language:“C”, ])
14. CLI\main()
14. CLI\main()
11. apnscpFunctionInterceptor::factory(Auth_Info_User, [username:“youngblood”, domain:“”, level:8, site_id:0, group_id:983, user_id:984, id:“pFBs5BT1vPkbJyD6DUYqqmXs8oS89p4b”, hotworker:null, language:“C”, ])
15. CLI\main()
Please refrain from instinctively relying upon AI.
The docs not only contain the correct solution to this problem, but also much terser and less prone to misinformation. See License management | ApisCP Docs
Guilty. Having a power outage and a mild panic to get this fixed at midnight to avoid customer impact, debugging errors that didn’t mean anything, trying to figure out why the UI wasn’t working, and then saw the license error and jumped to GenAI.
