Monthly system health report fails every month, always on the same task:
TASK [apnscp/php-filesystem-template : Link system extension directory to socket] *** fatal: [localhost]: FAILED! => {"changed": false, "gid": 0, "group": "root", "mode": "0777", "msg": "src file does not exist, use \"force=yes\" if you really want to create the link: /.socket/php/usr/lib64/20210902", "owner": "root", "path": "/home/virtual/FILESYSTEMTEMPLATE/siteinfo/usr/lib64/20210902", "size": 51, "src": "/.socket/php/usr/lib64/20210902", "state": "link", "uid": 0}
Current system state:
# ls -l /usr/lib64/2*
lrwxrwxrwx 1 root root 51 Aug 15 12:23 /usr/lib64/20131226 -> /.socket/php/multiphp/native/5.6/usr/lib64/20131226
lrwxrwxrwx 1 root root 51 Mar 27 10:37 /usr/lib64/20190902 -> /.socket/php/multiphp/native/7.4/usr/lib64/20190902
lrwxrwxrwx 1 root root 51 Mar 27 10:30 /usr/lib64/20200930 -> /.socket/php/multiphp/native/8.0/usr/lib64/20200930
lrwxrwxrwx 1 root root 51 Sep 1 03:47 /usr/lib64/20210902 -> /.socket/php/multiphp/native/8.1/usr/lib64/20210902
lrwxrwxrwx 1 root root 51 Mar 27 10:46 /usr/lib64/20220829 -> /.socket/php/multiphp/native/8.2/usr/lib64/20220829
# ls -l /home/virtual/FILESYSTEMTEMPLATE/siteinfo/usr/lib64/2*
lrwxrwxrwx 1 root root 51 Aug 15 12:23 /home/virtual/FILESYSTEMTEMPLATE/siteinfo/usr/lib64/20131226 -> /.socket/php/multiphp/native/5.6/usr/lib64/20131226
lrwxrwxrwx 1 root root 51 Mar 27 10:37 /home/virtual/FILESYSTEMTEMPLATE/siteinfo/usr/lib64/20190902 -> /.socket/php/multiphp/native/7.4/usr/lib64/20190902
lrwxrwxrwx 1 root root 51 Mar 27 10:30 /home/virtual/FILESYSTEMTEMPLATE/siteinfo/usr/lib64/20200930 -> /.socket/php/multiphp/native/8.0/usr/lib64/20200930
lrwxrwxrwx 1 root root 51 Sep 1 03:47 /home/virtual/FILESYSTEMTEMPLATE/siteinfo/usr/lib64/20210902 -> /.socket/php/multiphp/native/8.1/usr/lib64/20210902
lrwxrwxrwx 1 root root 51 Mar 27 10:46 /home/virtual/FILESYSTEMTEMPLATE/siteinfo/usr/lib64/20220829 -> /.socket/php/multiphp/native/8.2/usr/lib64/20220829
# ls -l /.socket/php/usr/lib64/
total 0
drwxr-xr-x 2 root root 299 Sep 1 03:30 build
# cpcmd scope:get php.multi
'8.1': system
'8.0': native
'7.4': native
'8.2': native
'5.6': native
# cpcmd scope:get php.version
8.1
# php -v
PHP 8.1.23 (cli) (built: Sep 1 2023 03:29:30) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.1.23, Copyright (c) Zend Technologies
with the ionCube PHP Loader v12.0.5, Copyright (c) 2002-2022, by ionCube Ltd.
with Zend OPcache v8.1.23, Copyright (c), by Zend Technologies
# cpcmd misc_cp_version
revision: fe41ead6f8212b4982f57c27bd455ddc22d19c4e
timestamp: 1693411074
ver_patch: 38
Temp workaround
This can be resolved by running
upcp -sbf php/install
upcp -sb apnscp/php-filesystem-template-
upcp -sb
But I’d like to know what the issue is that’s causing it to fail every month, and how I can go about fixing it for good. I see a related issue here but that looks like a one-off solution, rather than preventing this re-occurrence.
