how to install php ext-mongodb ? Could not find any instructions, some tips/pointers appreciated
LGTM
# upcp -sb --var="pecl_extensions=mongodb" php/install-extensions
PLAY [localhost] *******************************************************************************************************
included: /usr/local/apnscp/resources/playbooks/roles/php/install-extensions/tasks/verify-and-install.yml for localhost
TASK [php/install-extensions : Build and install mongodb library.] *****************************************************
changed: [localhost]
TASK [php/install-extensions : Check if mongodb loaded] ****************************************************************
included: /usr/local/apnscp/resources/playbooks/roles/php/install-extensions/tasks/populate-module-ini.yml for localhost
TASK [php/install-extensions : Add PECL module configuration] **********************************************************
included: /usr/local/apnscp/resources/playbooks/roles/common/handlers/restart-php-fpm.yml for localhost
RUNNING HANDLER [common : Stop php-fpm] ********************************************************************************
RUNNING HANDLER [common : Start php-fpm] *******************************************************************************
[WARNING]: flush_handlers task does not support when conditional
PLAY RECAP *************************************************************************************************************
localhost : ok=29 changed=5 unreachable=0 failed=0 skipped=9 rescued=0 ignored=0
