Unable to install PowerDNS on Rocky Linux 10
cpcmd scope:set cp.bootstrapper powerdns_enabled true
upcp -sb software/powerdns
Results in error:
TASK [software/powerdns-support/plays/powerdns-authoritative-setup : Install PowerDNS RPMs] ****************************
fatal: [localhost]: FAILED! => {"changed": false, "msg": "Failed to download metadata for repo 'powerdns-rec-49': Cannot download repomd.xml: Cannot download repodata/repomd.xml: All mirrors were tried", "rc": 1, "results": []}
Checking the PowerDNS repos, it appears that only 5.x is supported for EL10. Are there any options here without creating future headaches? I’m wanting this server maintain authoritative DNS for certain domains and push zones/updates to a cloud DNS secondary service via axfr by default.
Install and activate PowerDNS
Install fails due to PowerDNS 4.x packages being unavailable for EL10.
ApisCP version:
revision: f4e1af8849bfe9d7c80cc19fbd8ebf1722542029
timestamp: 1773194341
ver_pre: f4e1af884
Operating System:
6.12.0-124.40.1.el10_1.x86_64
