Is there a recommended procedure on how to change the database prefix for a given site? (Without incurring data loss).
site: example.com
current prefix: exa_
desired prefix: exa1_
I am aware that apiscp can only affect changes on the db server level and that configuration files of webapps would have to be manually modified.
Change mysql,dbaseprefix. Unit test circa 2022 that covers this.
This is causing issues. Its reproducable on two independant hosts.
Tested with a test-site rather than productive data. Missing Mysql grants after this.
steps to reproduce:
- Create new testsite (ie: mydbtest.tld)
- Use installer to throw a wordpress on it (so we have a test db with data)
- edit domain to have a different prefix (ie: -c ‘mysql,dbaseprefix’=‘mydbtest_’ )
- Log into nexus, go to mysql manager. See new DB - BUT you cannot assign any rights, as the grants are missing.
No grants found in database on mydbtest_.....' for user …’
Reproduced. I’ll look into this tomorrow
Thanks for the bug report. This has been fixed in edge at this time. I’ve expanded tests to ensure old users are properly converted as well.
