I keep receiving monit alerts that apnscp is not running, when I tail the logs on the server, there are no issues and ApisCP is running and everything works without issue. The pid file exists and has a proper timestamp.
I had the same issue on another server, a upcp -sb and reboot solved that but now monit is reporting httpd isn’t running and it is with no logged errors and a pid file that exists and has proper timestamps.
[p108] restart - failed protocol test [generic] at /usr/local/apnscp/storage/run/apnscp.sock -- cannot create a unix socket for /usr/local/apnscp/storage/run/apnscp/sock
The last message just came at 9:15am but the files have a timestamp of 9:02 from my last restart of the service.
httpd service is Apache, specific check is http://localhost/monit.html, which returns a blank 200 typically. If a check happens to go through during a reload or a restart or a child dying unexpectedly, then this can result in a false positive. Likewise a restart that replaces the pid file in /run/httpd.pid can result in this.
During each check batch
Check storage/logs/start.log and possibly access_log. This either occurs when a panel update coincides with a monitoring check, bots behaving badly (that the panel eventually blocks) or organically you’ve hit the worker count from multiple concurrent users interacting with the panel. To check if workers maxed,
Hmm, if it’s happening every 2 minutes then it sounds like “apnscp/sock” is to blame. It should be “apnscp.sock”. Check /etc/monit.d for that service definition, then when corrected run systemctl restart monit.
Every 2 minutes I get the monit alert via Pushover, but ApisCP is running and the pid and sock files are the ones created this morning after a server reboot.
[root@p108 ~]# ll /usr/local/apnscp/storage/run/
total 67684
-rw-r--r-- 1 root root 6 Mar 14 08:02 apnscpd.pid
srw------- 1 apnscp apnscp 0 Mar 14 08:02 apnscp.sock
Service was not restarting indefinitely but rather the event was stuck so every notification interval a new event dispatched as if it had restarted.
# monit validate apnscp
Process 'apnscp'
status OK
monitoring status Monitored
monitoring mode active
on reboot start
pid 204418
parent pid 1
uid 0
effective uid 0
gid 0
uptime 1d 4h 47m
threads 1
children 5
cpu 0.0%
cpu total 0.1%
memory 0.1% [56.9 MB]
memory total 0.7% [351.3 MB]
security attribute -
filedescriptors 10 [1.0% of 1024 limit]
total filedescriptors 84
read bytes 1.4 B/s [27.4 GB total]
disk read bytes 0 B/s [18.9 MB total]
disk read operations 0.7 reads/s [11848154 reads total]
write bytes 0.2 B/s [422.6 MB total]
disk write bytes 0 B/s [442.2 MB total]
disk write operations 0.0 writes/s [163589 writes total]
port response time 80.063 ms to localhost:2082 type TCP/IP protocol HTTP
unix socket response time 204.255 ms to /usr/local/apnscp/storage/run/apnscp.sock type TCP protocol generic
data collected Sat, 15 Mar 2025 12:49:26
First clue is from monit validate apnscp above. The uptime field indicates how long the service has remained running (no panel update, no restart on “major” releases).
Second clue is verifying events in /var/spool/monit:
# ls -la /var/spool/monit
-rw-r--r-- 1 root root 283 Mar 14 00:03 1741928608_564175c185a0
-rw-r--r-- 1 root root 283 Mar 14 00:05 1741928744_564175c185a0
-rw-r--r-- 1 root root 198 Mar 14 00:08 1741928880_564175c185a0
Remove those files, then systemctl restart monit. It may be related to tildeslash/monit #1120 that resulted in a regression. Addressing changes in Monit/Argos builds, I’ll have something out later this weekend once completed.
