https://%URL%:2083/apps/rspamd
rspamd dashboard is not loading
Service Unavailable Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Job for rspamd.service failed because the control process exitd with error code.
rspamd.service - rapid spam filtering system
Loaded: loaded (/usr/lib/systemd/system/rspamd.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2023-11-15 11:02:01 CET; 53s ago
Docs: https://rspamd.com/doc/
Process: 8838 ExecStart=/usr/bin/rspamd -c /etc/rspamd/rspamd.conf -f (code=exited, status=1/FAILURE)
Main PID: 8838 (code=exited, status=1/FAILURE)
Nov 15 11:02:01 cloud.qputerhq.nl systemd[1]: rspamd.service: Service RestartSec=100ms expired, scheduling restart.
Nov 15 11:02:01 cloud.qputerhq.nl systemd[1]: rspamd.service: Scheduled restart job, restart counter is at 5.
Nov 15 11:02:01 cloud.qputerhq.nl systemd[1]: Stopped rapid spam filtering system.
Nov 15 11:02:01 cloud.qputerhq.nl systemd[1]: rspamd.service: Start request repeated too quickly.
Nov 15 11:02:01 cloud.qputerhq.nl systemd[1]: rspamd.service: Failed with result 'exit-code'.
Nov 15 11:02:01 cloud.qputerhq.nl systemd[1]: Failed to start rapid spam filtering system.
# rpm -qi rspamd
Version : 3.8.0
Release : 49.git3e29be142.el8
Architecture: x86_64
Install Date: Tue 14 Nov 2023 06:31:29 AM EST
Group : System Environment/Daemons
License : Apache-2.0
Signature : RSA/SHA256, Mon 13 Nov 2023 11:35:03 AM EST, Key ID ffa232edbf21e25e
Source RPM : rspamd-3.8.0-49.git3e29be142.el8.src.rpm
Build Date : Mon 13 Nov 2023 11:28:50 AM EST
Build Host : 4d0597bfd293
Relocations : (not relocatable)
URL : https://rspamd.com
Summary : Rapid spam filtering system
Description :
Rspamd is a rapid, modular and lightweight spam filter. It is designed to work
with big amount of mail and can be easily extended with own filters written in
lua.
# rspamadm configtest
unknown worker attribute: quarantine_on_reject; worker type: controller
unknown worker attribute: extended_spam_headers; worker type: controller
unknown worker attribute: self_scan; worker type: rspamd_proxy
Stack trace (most recent call last):
#8 Object "", at 0xffffffffffffffff, in
#7 Object "/usr/bin/rspamadm", at 0x56361b9eeabd, in
#6 Object "/lib64/libc.so.6", at 0x7fc48d5b4d84, in __libc_start_main
#5 Object "/usr/bin/rspamadm", at 0x56361b9ee7f4, in
#4 Object "/usr/bin/rspamadm", at 0x56361b9f0214, in
#3 Object "/usr/lib64/rspamd/librspamd-server.so", at 0x7fc4962bfe64, in rspamd_config_read
#2 Object "/usr/lib64/rspamd/librspamd-server.so", at 0x7fc4963a72e9, in rspamd_language_detector_init
#1 Object "/usr/lib64/rspamd/librspamd-server.so", at 0x7fc4963adaa9, in rspamd_lang_detection_fasttext_init
#0 Object "/usr/lib64/rspamd/librspamd-server.so", at 0x7fc496590a31, in fasttext::FastText::FastText()
Unknown signal -1962494848
watf? exit
Here’s the issue as reported, rspamd/rspamd#4703. I’ll send out a FLARE update once this is patched in ~30 minutes.
FLARE released on edge. New incremental release will be due out shortly.
Edit: 3.2.39.1 released as well
