I’m running HAProxy → Varnish → Apache setup. HAProxy handles SSL on 443, so I need Apache on different ports.
Did this:
# Move HTTP to port 8081, disable SSL
cpcmd scope:set apache.ports '[8081,false]'
# Update configuration on all accounts
EditDomain --reconfig --all
EditDomain --rebuild --all
Problem:
- Main server vhost (
server.hostname.com) correctly uses port 8081 - Site vhosts (
wordpress.example.com) still generate for ports 80/443 in/etc/httpd/conf/virtual-httpd-built - Running
htrebuilddoesn’t update the site vhosts to use the new ports - This causes Apache to route requests to server root instead of site document root (403 errors)
Expected:
Site vhosts should be generated for ports 8081/8443 (or 8081 only if ssl_port=false) to match the httpd config.
Question:
How do I force site vhosts to regenerate with the correct ports from config.ini?
What is the correct approach of achieving the goal? (Put vHost behind HAproxy/other ports)
