SSL Renewal failed for each wildcard domain.
Please provide detailed steps to reproduce the bug. Include any necessary code snippets, commands, or configuration files.
- env DEBUG=1 cpcmd -d sitexxx letsencrypt:renew
SSL Renewal works flawless
Error Message
DEBUG : SSL challenge attempt: dns (*.one-ofmay-domains.de)
(TypeError) EXCEPTION: str_replace(): Argument #3 ($subject) must be of type array|string, null given
[/usr/local/apnscp/lib/Opcenter/Dns/Providers/Hetzner/Record.php:28]
0. str_replace([" "" ", "" ""], ["", ""], null)
1. Opcenter\Dns\Providers\Hetzner\Record->formatTxt()
[/usr/local/apnscp/lib/Opcenter/Dns/Record.php:67]
2. Opcenter\Dns\Record->__construct("one-ofmay-domains.de", [name:"_acme-challenge", rr:"TXT", parameter:null])
[/usr/local/apnscp/lib/Opcenter/Dns/Providers/Hetzner/Record.php:23]
3. Opcenter\Dns\Providers\Hetzner\Record->__construct("one-ofmay-domains.de", [name:"_acme-challenge", rr:"TXT", parameter:null])
[/usr/local/apnscp/lib/Module/Support/Dns.php:155]
4. Module\Support\Dns::createRecord("one-ofmay-domains.de", [name:"_acme-challenge", rr:"TXT", parameter:null])
[/usr/local/apnscp/lib/modules/dns.php:1318]
5. Dns_Module->record_exists("one-ofmay-domains.de", "_acme-challenge", "TXT")
[/usr/local/apnscp/lib/Module/Skeleton/Standard.php:145]
6. Module\Skeleton\Standard->_invoke("record_exists", ["one-ofmay-domains.de", "_acme-challenge", "TXT"])
[/usr/local/apnscp/lib/apnscpfunction.php:992]
7. apnscpFunctionInterceptor->call("dns_record_exists", ["one-ofmay-domains.de", "_acme-challenge", "TXT"])
[/usr/local/apnscp/lib/apnscpfunction.php:932]
8. apnscpFunctionInterceptor->__call("dns_record_exists", ["one-ofmay-domains.de", "_acme-challenge", "TXT"])
[/usr/local/apnscp/lib/Opcenter/Crypto/Letsencrypt/Solvers/Dns.php:44]
9. Opcenter\Crypto\Letsencrypt\Solvers\Dns->resolve()
[/usr/local/apnscp/lib/Opcenter/Crypto/Letsencrypt/AcmeDispatcher.php:296]
10. Opcenter\Crypto\Letsencrypt\AcmeDispatcher->solve(AcmePhp\Core\Protocol\CertificateOrder)
[/usr/local/apnscp/lib/Opcenter/Crypto/Letsencrypt/AcmeDispatcher.php:175]
11. Opcenter\Crypto\Letsencrypt\AcmeDispatcher->issue(["one-ofmay-domains.de", "*.one-ofmay-domains.de"])
[/usr/local/apnscp/lib/Module/Support/Letsencrypt.php:256]
12. Module\Support\Letsencrypt->requestReal(["one-ofmay-domains.de", "*.one-ofmay-domains.de"], "site9", true)
[/usr/local/apnscp/lib/modules/letsencrypt.php:390]
13. Letsencrypt_Module->request(["*.one-ofmay-domains.de", "one-ofmay-domains.de"], true)
[/usr/local/apnscp/lib/modules/letsencrypt.php:126]
14. Letsencrypt_Module->renew()
15. Module\Skeleton\Standard->_invoke("renew", )
16. apnscpFunctionInterceptor->call("letsencrypt_renew", )
[/usr/local/apnscp/lib/CLI/cmd.php:55]
17. CLI\__call("letsencrypt_renew", )
[/usr/local/apnscp/lib/CLI/cmd.php:574]
18. CLI\main()
[/usr/local/apnscp/bin/cmd:7]
18. CLI\main()
revision: dd6024bcb1aa8eafed84173f3f25c00cce226c86
timestamp: 1722360217
ver_patch: 44
Operating System: 4.18.0-552.el8.x86_64
Hetzner DNS
Enabling or disabling the IP Check / Verification didn´t change the behaviour.
current Workaround: Creating non-wildcard Domains SSL Certs work (via http Challenge)
Further Information:
Doing the same via WebGui:
results in blank screen, no Error from the WebGui, with unformatted same errors , as above, in start.log
Only Browser Back Button works
ALSO: the SSL Cert for the WebServer / APSCP Panel, Mail and so on are expired, and can´t be renewed
