hey folks - im trying to generate a new cert for a site, as it seemed to not do it automatically - but when i click generate & install i just get a white page, i enabled debug and i get the following
I just add the subdomains/wildcard etc, tick agree, click the button
Get a new cert
0. Error_Reporter::get_debug_bt()
[/usr/local/apnscp/lib/error_reporter.php:840]
1. Error_Reporter::print_debug_bt()
[/usr/local/apnscp/lib/datastream.php:422]
2. DataStream->pipeline("")
[/usr/local/apnscp/lib/datastream.php:394]
3. DataStream->query("letsencrypt_request", ["www.zfituk.co.uk", "*.zfituk.co.uk", "zfituk.co.uk"], false, null)
[/usr/local/apnscp/lib/Module/Skeleton/Standard.php:200]
4. Module\Skeleton\Standard->query("letsencrypt_request", ["www.zfituk.co.uk", "*.zfituk.co.uk", "zfituk.co.uk"], false, null)
[/usr/local/apnscp/lib/modules/letsencrypt.php:292]
5. Letsencrypt_Module->request(["www.zfituk.co.uk", "*.zfituk.co.uk", "zfituk.co.uk"], false)
[/usr/local/apnscp/lib/Module/Skeleton/Standard.php:145]
6. Module\Skeleton\Standard->_invoke("request", [["www.zfituk.co.uk", "*.zfituk.co.uk", "zfituk.co.uk"], false])
[/usr/local/apnscp/lib/apnscpfunction.php:983]
7. apnscpFunctionInterceptor->call("letsencrypt_request", [["www.zfituk.co.uk", "*.zfituk.co.uk", "zfituk.co.uk"], false])
[/usr/local/apnscp/lib/apnscpFunctionInterceptorTrait.php:34]
8. Page_Container->afiCall("letsencrypt_request", [["www.zfituk.co.uk", "*.zfituk.co.uk", "zfituk.co.uk"], false])
[/usr/local/apnscp/lib/html/page_container.php:625]
9. Page_Container->__call("letsencrypt_request", [["www.zfituk.co.uk", "*.zfituk.co.uk", "zfituk.co.uk"], false])
[/usr/local/apnscp/apps/ssl/ssl.php:373]
10. apps\ssl\Page->_installLetsEncrypt([["www.zfituk.co.uk", "*.zfituk.co.uk", "zfituk.co.uk"], subdomain:"*", domain:"zfituk.co.uk", c:"us", l:"", o:"", ou:"", ])
[/usr/local/apnscp/apps/ssl/ssl.php:138]
11. apps\ssl\Page->on_postback([["www.zfituk.co.uk", "*.zfituk.co.uk", "zfituk.co.uk"], subdomain:"*", domain:"zfituk.co.uk", c:"us", l:"", o:"", ou:"", ])
[/usr/local/apnscp/lib/html/page_container.php:1083]
12. Page_Container->_processPostback()
[/usr/local/apnscp/lib/html/page_container.php:1031]
13. Page_Container->handle_request()
[/usr/local/apnscp/public/index.php:99]
object(apnscpObject)#218 (8) { ["command"]=> string(19) "letsencrypt_request" ["args"]=> array(3) { [0]=> array(3) { [0]=> string(16) "www.zfituk.co.uk" [1]=> string(14) "*.zfituk.co.uk" [2]=> string(12) "zfituk.co.uk" } [1]=> bool(false) [2]=> NULL } ["error"]=> NULL ["session_id"]=> string(32) "FJG7Ypjm59JyGjeAdFmEGgUgvjZBCiWC" ["returned_data"]=> NULL ["options"]=> NULL ["error_buffer"]=> NULL ["ip":"apnscpObject":private]=> string(14) "86.142.184.255" }
0. Error_Reporter::trigger_fatal("`letsencrypt_request': crash or other nasty error detected", ["letsencrypt_request"])
[/usr/local/apnscp/lib/log_wrapper.php:50]
1. fatal("`%s': crash or other nasty error detected", "letsencrypt_request")
[/usr/local/apnscp/lib/datastream.php:426]
ApisCP version:
revision: 3ec2e7884c258580fa707cfe827a4269861007c6
timestamp: 1730519492
ver_patch: 45
ver_pre: ‘’
debug: true
Operating System: 4.18.0-553.36.1.el8_10.x86_64
