syntax error, unexpected ‘=’
came to my server today and theres a bunch of git merges halfway done, like there are >>>>>> head and stuff like that all throughout certain files apnscp wont restart and is claiming httpd_args is an empty string, ive tried pulling the latyest tag in the /usr/local/apnscp git dir but everything seems broken would love to get some help and im sorry for the vagueness i came across this today and it was broken when i got to it so im not sure what exactly went wrong.
try to restart server post november patch
apnscp to be running
apnscp is failed and i cannot access the panel
ApisCP version: cpcmd misc:cp-version doesnt run
Failed loading /usr/local/apnscp/sys/php/20230831/ioncube_loader_lin_8.3.so: /usr/local/apnscp/sys/php/20230831/ioncube_loader_lin_8.3.so: cannot open shared object file: No such file or directory
Failed loading /usr/local/apnscp/sys/php/20230831/opcache.so: /usr/local/apnscp/sys/php/20230831/opcache.so: cannot open shared object file: No such file or directory
PHP Warning: PHP Startup: Unable to load dynamic library ‘apcu.so’ (tried: /usr/local/apnscp/sys/php/20230831/apcu.so (/usr/local/apnscp/sys/php/20230831/apcu.so: cannot open shared object file: No such file or directory), /usr/local/apnscp/sys/php/20230831/apcu.so.so (/usr/local/apnscp/sys/php/20230831/apcu.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘igbinary.so’ (tried: /usr/local/apnscp/sys/php/20230831/igbinary.so (/usr/local/apnscp/sys/php/20230831/igbinary.so: cannot open shared object file: No such file or directory), /usr/local/apnscp/sys/php/20230831/igbinary.so.so (/usr/local/apnscp/sys/php/20230831/igbinary.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘redis.so’ (tried: /usr/local/apnscp/sys/php/20230831/redis.so (/usr/local/apnscp/sys/php/20230831/redis.so: cannot open shared object file: No such file or directory), /usr/local/apnscp/sys/php/20230831/redis.so.so (/usr/local/apnscp/sys/php/20230831/redis.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
PHP Warning: PHP Startup: Unable to load dynamic library ‘dbus.so’ (tried: /usr/local/apnscp/sys/php/20230831/dbus.so (/usr/local/apnscp/sys/php/20230831/dbus.so: cannot open shared object file: No such file or directory), /usr/local/apnscp/sys/php/20230831/dbus.so.so (/usr/local/apnscp/sys/php/20230831/dbus.so.so: cannot open shared object file: No such file or directory)) in Unknown on line 0
WARNING: syntax error, unexpected ‘=’ in /usr/local/apnscp/config/config.ini on line 31
[/usr/local/apnscp/lib/config.php:204]
0. parse_ini_file(“/usr/local/apnscp/config/config.ini”, true, 2)
1. include(“/usr/local/apnscp/lib/config.php”)
[/usr/local/apnscp/lib/constants.php:58]
2. {closure}()
[/usr/local/apnscp/lib/constants.php:104]
3. include(“/usr/local/apnscp/lib/constants.php”)
[/usr/local/apnscp/lib/apnscpcore.php:78]
4. include(“/usr/local/apnscp/lib/apnscpcore.php”)
[/usr/local/apnscp/lib/CLI/cmd.php:15]
5. include(“/usr/local/apnscp/lib/CLI/cmd.php”)
[/usr/local/apnscp/bin/cmd:6]
FATAL : fatal(): failed parsing /usr/local/apnscp/config/config.ini' 0. Error_Reporter::trigger_fatal("failed parsing /usr/local/apnscp/config/config.ini’“, [”/usr/local/apnscp/config/config.ini"])
[/usr/local/apnscp/lib/log_wrapper.php:50]
1. fatal(“failed parsing `%s’”, “/usr/local/apnscp/config/config.ini”)
[/usr/local/apnscp/lib/config.php:205]
2. include(“/usr/local/apnscp/lib/config.php”)
3. {closure}()
4. include(“/usr/local/apnscp/lib/constants.php”)
5. include(“/usr/local/apnscp/lib/apnscpcore.php”)
6. include(“/usr/local/apnscp/lib/CLI/cmd.php”)
Operating System: uname -r
rocky 10.2
Provide any additional information about the bug, such as error messages, logs, screenshots, or any other relevant details.
happy to provide you anything you need just let me know
2. {closure}()
[/usr/local/apnscp/artisan:19]
     0. parse_ini_file("/usr/local/apnscp/config/config.ini", true, 2)
     1. include("/usr/local/apnscp/lib/config.php")
     2. {closure}()
     3. include("/usr/local/apnscp/lib/constants.php")
     4. include("/usr/local/apnscp/lib/apnscpcore.php")
3. {closure}()
by some miracle ive gotten upcp -sb to run might be fine will report back soon
okay i think i found the issue, it seems to think ive tampered with the license validator… is there any way for me to revert that file? i have 3 pro licenses so im not exactly trying to avoid the license thing not sure why this has happened
# reset codebase
upcp --reset
# platform scrub
upcp -sbfv
when running the last command i get this error
TASK [system/nss : Remove systemd from FST nsswitch.conf] ****************************************************
fatal: [localhost]: FAILED! => {“changed”: false, “msg”: “Path /home/virtual/FILESYSTEMTEMPLATE/siteinfo/etc/n
sswitch.conf does not exist !”, “rc”: 257}
ll /home/virtual/FILESYSTEMTEMPLATE/siteinfo/etc/
I bet nsswitch.conf is a symlink
I bet you’ll find issues in pam.d as well.
ll /home/virtual/FILESYSTEMTEMPLATE/siteinfo/etc/pam.d/
yes does appear so
I ran into this issue on a server recently, the fix that worked for me was to delete those symlinks and recreate the files using file content from another server of the same OS version and ApisCP build.
Maybe Matt will have a fix, but that worked for me and resolved some of the oddities.
I’d need a reliable way to reproduce the issue to explore it further.
ill attempt this i guess, thanks for the suggestion
