Hello. Ex. Plesk hostage here. Very excited to discover ApisCP. Plenty to learn from. Seriously excited like when I had 20 ![]()
Can someone clarify, system requirements vary a bit and I am not trying to nitpick but what does this mean:
https://docs.apiscp.com/ - system requirements here says CentOS/RedHat 7+
but then here:
Installation | ApisCP Docs - * RHEL/CentOS 7.4+/8+ or CentOS 8 Stream or Rocky Linux or AlmaLinux
Because of the deviation, I am confused. Does the + sign after 8 indicates that AlmaLinux 9 is supported? Or is that the sign that all consecutive releases within version 8 are supported?
Just asking whatās the best way to start so a bit confused with system requirements. I am fine with AlmaLinux 8.10 (Cerulean Leopard) but if 9 is supported then why not?
If you were starting today which OS you pick for ApisCP
Also, can someone explain lifetime licenses? I would love to purchase some. Thereās a " Save 50% on all lifetime licenses with code ANNIVERSARY" on the main site but in the backend, thereās no place to enter the code at the checkout. Though perhaps it is on step 2in the checkout? I intend to purchase three licenses even though I only need two - one is just to support the ApisCP project. ApisCP seems like a fantastic alternative to devastating āI want to be all and everything so here are mediocre featuresā commercial alternatives.
ApisCP - a moment of fresh air haha
