trying to move sites to a new server. new server is a fresh install. both new and old server just finished a fresh upcp -sbf. no issues/failures.
source server:
cpcmd misc_cp_version`
revision: f8f76f4066100e8966476975b633920e87ede7e5
timestamp: 1783266206
ver_pre: 70-gf8f76f406
destination server:
ver_pre: f8f76f406
error:
# apnscp_php /usr/local/apnscp/bin/scripts/transfersite.php -s testserver.redacted.tld testdomain.tld
beginning migration: testdomain.tld (stage 0)
creating site on testserver.redacted.tld
synchronizing users
copying user config
synchronizing passwords
syncing mysql databases...
ERROR : unknown(): migration failed - unhandled exception
0. Error_Reporter::add_error("migration failed - unhandled exception", )
[/usr/local/apnscp/lib/log_wrapper.php:72]
1. error("migration failed - unhandled exception")
[/usr/local/apnscp/bin/scripts/transfersite.php:247]
FAILURE: aliases_synchronize_changes
Util_Process::formatDataCallProc(): EditDomain: (5f765583-ee92-579a-a60b-f8a7ec576e18 apnscpException) EXCEPTION: fatal(): unknown configuration value(s) `reseller_id' located in service `reseller'
[/usr/local/apnscp/lib/error_reporter.php:711]
0. Error_Reporter::append_msg("fatal(): unknown configuration value(s) `reseller_id' located in service `reseller'", ["fatal", "unknown configuration value(s) `reseller_id' located in service `reseller'"], 64)
[/usr/local/apnscp/lib/error_reporter.php:1349]
1. Error_Reporter::trigger_fatal("unknown configuration value(s) `reseller_id' located in service `reseller'", ["reseller_id", "reseller"])
[/usr/local/apnscp/lib/log_wrapper.php:50]
2. fatal("unknown configuration value(s) `%s' located in service `%s'", "reseller_id", "reseller")
[/usr/local/apnscp/lib/Opcenter/SiteConfiguration.php:217]
3. Opcenter\SiteConfiguration->__construct("site1", [[], [[enabled:1, subnum:null, version:3.2, webserver:"testdomain.tld"], [[cpasswd:null, enabled:1, iprestrict:50, ]]]])
[/usr/local/apnscp/lib/Opcenter/Account/Edit.php:103]
4. Opcenter\Account\Edit->installServices()
[/usr/local/apnscp/lib/Opcenter/Account/Edit.php:88]
5. Opcenter\Account\Edit->exec()
[/usr/local/apnscp/bin/EditDomain:119]
Aliases_Module::_synchronize_changes(): failed to activate domain changes
Line 86
#0 /usr/local/apnscp/lib/Util/API.php(86): SoapClient->__call('aliases_synchro...', Array)
#1 /usr/local/apnscp/lib/CLI/Transfer.php(238): Util_API->__call('aliases_synchro...', Array)
#2 /usr/local/apnscp/lib/CLI/Transfer.php(1041): CLI_Transfer->_sync('remote', 'aliases_synchro...')
#3 /usr/local/apnscp/lib/CLI/Transfer.php(167): CLI_Transfer->_sync_addon_domains()
#4 /usr/local/apnscp/bin/scripts/transfersite.php(233): CLI_Transfer->process()
#5 {main}
Tried without success: EditDomain --reconfig --all
reseller,reseller_id was renamed to reseller,id. That reference is either present in the site metadata (/home/virtual/siteXX/info) or the plan definition in /usr/local/apnscp/resources/templates/plans.
edit: i see.
I have solved this with a bit of bash scripting for mass edits.
