Hey. I am trying to find an uninstall button for the Web App Ghost.
I there any solution to uninstall in a simple way?
Regards
Erik
Regards
Erik
It’s located in the App Meta tray. One caveat is that uninstallation does not automatically remove contents if the app is installed under /var/www/html (~/mainwebsite_html). Rationale being that it’s often used for more than just a single website and uninstalling an app recursively deletes the directory.
