Update Migrations Fail
When running: cd /usr/local/apnscp && ./artisan migrate --force
The migrations fail on the following:
TASK [apnscp/install-services : template] **************************************
msg: ‘AnsibleUndefinedVariable: ‘‘php_fst_service’’ is undefined’
Stack Trace:
STDERR:
[/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:212]
         0. Lararia\Database\Migrations\PlatformMigrator->runMigration("2025_08_05_130434_service-master-classes", "up", [step:true])
            [/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:129]
         1. Lararia\Database\Migrations\PlatformMigrator->runUp("/usr/local/apnscp/resources/playbooks/migrations/2025_08_05_130434_service-master-classes.yml", 24, false)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:165]
         2. Illuminate\Database\Migrations\Migrator->runPending(["/usr/local/apnscp/resources/playbooks/migrations/2025_08_05_130434_service-master-classes.yml", "/usr/local/apnscp/resources/playbooks/migrations/2025_08_31_101120_rhel10-libraries.yml", "/usr/local/apnscp/resources/playbooks/migrations/2025_09_30_152814_imagick-el9-deps.yml", "/usr/local/apnscp/resources/playbooks/migrations/2025_12_08_193711_atd-el10-updates.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_02_09_105615_rspamd-autolearn.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_05_30_111720_el10-libfido2-dep.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_06_03_091839_update-mailq-visibility.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_07_24_130718_php-fpm-signal.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_10_07_142729_php-fpm-durable-cache.yml"], )
            [/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:93]
         3. Lararia\Database\Migrations\PlatformMigrator->runPending(["/usr/local/apnscp/resources/playbooks/migrations/2025_08_05_130434_service-master-classes.yml", "/usr/local/apnscp/resources/playbooks/migrations/2025_08_31_101120_rhel10-libraries.yml", "/usr/local/apnscp/resources/playbooks/migrations/2025_09_30_152814_imagick-el9-deps.yml", "/usr/local/apnscp/resources/playbooks/migrations/2025_12_08_193711_atd-el10-updates.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_02_09_105615_rspamd-autolearn.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_05_30_111720_el10-libfido2-dep.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_06_03_091839_update-mailq-visibility.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_07_24_130718_php-fpm-signal.yml", "/usr/local/apnscp/resources/playbooks/migrations/2026_10_07_142729_php-fpm-durable-cache.yml"], )
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:110]
         4. Illuminate\Database\Migrations\Migrator->run(["/usr/local/apnscp/resources/playbooks/migrations"], [pretend:false, step:0, rollback:false, ff:false])
            [/usr/local/apnscp/lib/Lararia/Database/Migrations/PlatformMigrator.php:41]
         5. Lararia\Database\Migrations\PlatformMigrator->run(["/usr/local/apnscp/resources/playbooks/migrations"], [pretend:false, step:0, rollback:false, ff:false])
            [/usr/local/apnscp/lib/Lararia/Console/Commands/PlatformMigration.php:76]
         6. Lararia\Console\Commands\PlatformMigration->handle()
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:36]
         7. Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/Util.php:37]
         8. Illuminate\Container\Util::unwrapIfClosure()
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:93]
         9. Illuminate\Container\BoundMethod::callBoundMethod(Lararia\Application, [], [Lararia\Console\Commands\PlatformMigration, "handle"], )
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:35]
        10. Illuminate\Container\BoundMethod::call(Lararia\Application, [], [Lararia\Console\Commands\PlatformMigration, "handle"], null)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Container/Container.php:596]
        11. Illuminate\Container\Container->call([Lararia\Console\Commands\PlatformMigration, "handle"])
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Command.php:134]
        12. Illuminate\Console\Command->execute(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Command/Command.php:298]
        13. Symfony\Component\Console\Command\Command->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Command.php:120]
        14. Illuminate\Console\Command->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Application.php:1040]
        15. Symfony\Component\Console\Application->doRunCommand(Lararia\Console\Commands\PlatformMigration, Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Application.php:301]
        16. Symfony\Component\Console\Application->doRun(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/symfony/console/Application.php:171]
        17. Symfony\Component\Console\Application->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Application.php:93]
        18. Illuminate\Console\Application->run(Symfony\Component\Console\Input\ArrayInput, Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Console/Application.php:184]
        19. Illuminate\Console\Application->call("migrate:platform", [--force:true, --pretend:false], Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:263]
        20. Illuminate\Foundation\Console\Kernel->call("migrate:platform", [--force:true, --pretend:false], Illuminate\Console\OutputStyle)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php:261]
        21. Illuminate\Support\Facades\Facade::__callStatic("call", ["migrate:platform", [[--force:true, --pretend:false], Illuminate\Console\OutputStyle]])
            [/usr/local/apnscp/lib/Lararia/Console/Commands/Migrate.php:55]
        22. Lararia\Console\Commands\Migrate->handle()
        23. Illuminate\Container\BoundMethod::Illuminate\Container\{closure}()
        24. Illuminate\Container\Util::unwrapIfClosure()
        25. Illuminate\Container\BoundMethod::callBoundMethod(Lararia\Application, [], [Lararia\Console\Commands\Migrate, "handle"], )
        26. Illuminate\Container\BoundMethod::call(Lararia\Application, [], [Lararia\Console\Commands\Migrate, "handle"], null)
        27. Illuminate\Container\Container->call([Lararia\Console\Commands\Migrate, "handle"])
        28. Illuminate\Console\Command->execute(Symfony\Component\Console\Input\ArgvInput, Illuminate\Console\OutputStyle)
        29. Symfony\Component\Console\Command\Command->run(Symfony\Component\Console\Input\ArgvInput, Illuminate\Console\OutputStyle)
        30. Illuminate\Console\Command->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        31. Symfony\Component\Console\Application->doRunCommand(Lararia\Console\Commands\Migrate, Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        32. Symfony\Component\Console\Application->doRun(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        33. Symfony\Component\Console\Application->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
        34. Illuminate\Console\Application->run(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
            [/usr/local/apnscp/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:129]
        35. Illuminate\Foundation\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
            [/usr/local/apnscp/lib/Lararia/Console/Kernel.php:31]
        36. Lararia\Console\Kernel->handle(Symfony\Component\Console\Input\ArgvInput, Symfony\Component\Console\Output\ConsoleOutput)
            [/usr/local/apnscp/artisan:58]
[root@s1 apnscp]# cpcmd misc:cp-version
revision: 609d738f5c212e5ede9a5768e5b6c1f6dfa66b1c
timestamp: 1792063336
ver_patch: 49
ver_pre: ‘’
checksum: 1352899363843ac
Operating System: 4.18.0-553.109.1.el8_10.x86_64
Run upcp -vm '*durable-cache*' to run this migration directly. Provide me with the preceding plays leading up to this.
Running that migration directly didn’t seem to give any error:
TASK [apnscp/install-services : Install php-fpm@] ***************************************************************************************************************************************************************************************************************************************
ok: [localhost] => (item=Copy /usr/local/apnscp/resources/playbooks/roles/php/install/files/php-fpm-systemd-group.service -> /etc/systemd/system/php-fpm@.service) => {"ansible_loop_var": "file", "changed": false, "checksum": "003e6dc52617017dc828a7d6eade2ecb032e1693", "dest": "/etc/systemd/system/php-fpm@.service", "file": {"dest": "/etc/systemd/system/php-fpm@.service", "src": "/usr/local/apnscp/resources/playbooks/roles/php/install/files/php-fpm-systemd-group.service"}, "gid": 0, "group": "root", "mode": "0644", "owner": "root", "path": "/etc/systemd/system/php-fpm@.service", "size": 250, "state": "file", "uid": 0}
TASK [apnscp/install-services : Disable php-fpm@ service] *******************************************************************************************************************************************************************************************************************************
ok: [localhost] => {"changed": false, "name": "php-fpm@", "status": {}}
TASK [apnscp/install-services : Install php-fpm-MAIN.service] ***************************************************************************************************************************************************************************************************************************
ok: [localhost] => (item=Copy /tmp/ansible.482wagys -> /etc/systemd/system/php-fpm-MAIN.service) => {"ansible_loop_var": "file", "changed": false, "checksum": "94c0de140f1d22aea9b20c64325ff6bbbaff4eee", "dest": "/etc/systemd/system/php-fpm-MAIN.service", "file": {"dest": "/etc/systemd/system/php-fpm-MAIN.service", "src": "/tmp/ansible.482wagys"}, "gid": 0, "group": "root", "mode": "0644", "owner": "root", "path": "/etc/systemd/system/php-fpm-MAIN.service", "size": 2267, "state": "file", "uid": 0}
TASK [apnscp/install-services : Disable php-fpm-MAIN.service service] *******************************************************************************************************************************************************************************************************************
changed: [localhost] => {"changed": true, "enabled": false, "name": "php-fpm-MAIN.service", "status": {"ActiveEnterTimestamp": "Sat 2026-08-01 04:18:23 EDT", "ActiveEnterTimestampMonotonic": "12614539728893", "ActiveExitTimestamp": "Fri 2026-10-16 20:44:14 EDT", "ActiveExitTimestampMonotonic": "19240091160361", "ActiveState": "inactive", "After": "network.target tmp.mount sysinit.target system.slice -.mount mariadb.service basic.target php-fpm-MAIN.socket systemd-tmpfiles-setup.service systemd-journald.socket php-fpm@MAIN.socket postgresql-14.service", "AllowIsolate": "no", "AllowedCPUs": "", "AllowedMemoryNodes": "", "AmbientCapabilities": "", "AssertResult": "yes", "AssertTimestamp": "Sat 2026-08-01 04:18:18 EDT", "AssertTimestampMonotonic": "12614534889410", "Before": "shutdown.target", "BlockIOAccounting": "no", "BlockIOWeight": "[not set]", "CPUAccounting": "no", "CPUAffinity": "", "CPUAffinityFromNUMA": "no", "CPUQuotaPerSecUSec": "infinity", "CPUQuotaPeriodUSec": "infinity", "CPUSchedulingPolicy": "0", "CPUSchedulingPriority": "0", "CPUSchedulingResetOnFork": "no", "CPUShares": "[not set]", "CPUUsageNSec": "[not set]", "CPUWeight": "[not set]", "CacheDirectoryMode": "0755", "CanFreeze": "yes", "CanIsolate": "no", "CanReload": "yes", "CanStart": "yes", "CanStop": "yes", "CapabilityBoundingSet": "cap_setgid cap_setuid", "CollectMode": "inactive", "ConditionResult": "yes", "ConditionTimestamp": "Sat 2026-08-01 04:18:18 EDT", "ConditionTimestampMonotonic": "12614534889403", "ConfigurationDirectoryMode": "0755", "Conflicts": "shutdown.target", "ControlPID": "0", "DefaultDependencies": "yes", "DefaultMemoryLow": "0", "DefaultMemoryMin": "0", "Delegate": "no", "Description": "PHP worker for MAIN", "DevicePolicy": "closed", "DynamicUser": "no", "EffectiveCPUs": "", "EffectiveMemoryNodes": "", "Environment": "FPM_SOCKETS=/run/php-fpm/MAIN.socket=3", "ExecMainCode": "1", "ExecMainExitTimestamp": "Fri 2026-10-16 20:44:14 EDT", "ExecMainExitTimestampMonotonic": "19240091220208", "ExecMainPID": "4012966", "ExecMainStartTimestamp": "Sat 2026-08-01 04:18:18 EDT", "ExecMainStartTimestampMonotonic": "12614534892372", "ExecMainStatus": "0", "ExecReload": "{ path=/bin/kill ; argv[]=/bin/kill -USR2 $MAINPID ; ignore_errors=no ; start_time=[n/a] ; stop_time=[n/a] ; pid=0 ; code=(null) ; status=0/0 }", "ExecStart": "{ path=/usr/sbin/php-fpm ; argv[]=/usr/sbin/php-fpm --nodaemonize --fpm-config=/etc/php-fpm.conf ; ignore_errors=no ; start_time=[n/a] ; stop_time=[n/a] ; pid=0 ; code=(null) ; status=0/0 }", "FailureAction": "none", "FileDescriptorStoreMax": "0", "FragmentPath": "/etc/systemd/system/php-fpm-MAIN.service", "FreezerState": "running", "GID": "[not set]", "Group": "apache", "GuessMainPID": "yes", "IOAccounting": "no", "IOSchedulingClass": "0", "IOSchedulingPriority": "0", "IOWeight": "[not set]", "IPAccounting": "no", "IPEgressBytes": "18446744073709551615", "IPEgressPackets": "18446744073709551615", "IPIngressBytes": "18446744073709551615", "IPIngressPackets": "18446744073709551615", "Id": "php-fpm-MAIN.service", "IgnoreOnIsolate": "no", "IgnoreSIGPIPE": "yes", "InactiveEnterTimestamp": "Fri 2026-10-16 20:44:14 EDT", "InactiveEnterTimestampMonotonic": "19240091220391", "InactiveExitTimestamp": "Sat 2026-08-01 04:18:18 EDT", "InactiveExitTimestampMonotonic": "12614534892459", "InvocationID": "5ee4851b4e04467db475739632d96c62", "JobRunningTimeoutUSec": "infinity", "JobTimeoutAction": "none", "JobTimeoutUSec": "infinity", "KeyringMode": "private", "KillMode": "control-group", "KillSignal": "15", "LimitAS": "infinity", "LimitASSoft": "infinity", "LimitCORE": "infinity", "LimitCORESoft": "0", "LimitCPU": "infinity", "LimitCPUSoft": "infinity", "LimitDATA": "infinity", "LimitDATASoft": "infinity", "LimitFSIZE": "4294967296", "LimitFSIZESoft": "4294967296", "LimitLOCKS": "infinity", "LimitLOCKSSoft": "infinity", "LimitMEMLOCK": "65536", "LimitMEMLOCKSoft": "65536", "LimitMSGQUEUE": "819200", "LimitMSGQUEUESoft": "819200", "LimitNICE": "0", "LimitNICESoft": "0", "LimitNOFILE": "262144", "LimitNOFILESoft": "1024", "LimitNPROC": "63913", "LimitNPROCSoft": "63913", "LimitRSS": "infinity", "LimitRSSSoft": "infinity", "LimitRTPRIO": "0", "LimitRTPRIOSoft": "0", "LimitRTTIME": "infinity", "LimitRTTIMESoft": "infinity", "LimitSIGPENDING": "63913", "LimitSIGPENDINGSoft": "63913", "LimitSTACK": "infinity", "LimitSTACKSoft": "8388608", "LoadState": "loaded", "LockPersonality": "no", "LogLevelMax": "-1", "LogRateLimitBurst": "0", "LogRateLimitIntervalUSec": "0", "LogsDirectoryMode": "0755", "MainPID": "0", "MemoryAccounting": "yes", "MemoryCurrent": "[not set]", "MemoryDenyWriteExecute": "no", "MemoryHigh": "infinity", "MemoryLimit": "infinity", "MemoryLow": "0", "MemoryMax": "infinity", "MemoryMin": "0", "MemorySwapMax": "infinity", "MountAPIVFS": "no", "MountFlags": "", "NFileDescriptorStore": "0", "NRestarts": "0", "NUMAMask": "", "NUMAPolicy": "n/a", "Names": "php-fpm-MAIN.service", "NeedDaemonReload": "no", "Nice": "0", "NoNewPrivileges": "yes", "NonBlocking": "no", "NotifyAccess": "main", "OOMScoreAdjust": "500", "OnFailureJobMode": "replace", "PartOf": "php-fpm-MAIN.socket", "PermissionsStartOnly": "yes", "Perpetual": "no", "PrivateDevices": "yes", "PrivateMounts": "no", "PrivateNetwork": "no", "PrivateTmp": "yes", "PrivateUsers": "no", "ProtectControlGroups": "no", "ProtectHome": "tmpfs", "ProtectKernelModules": "no", "ProtectKernelTunables": "no", "ProtectSystem": "yes", "ReadOnlyPaths": "/usr/share/pear", "ReadWritePaths": "/var/lib", "RefuseManualStart": "no", "RefuseManualStop": "no", "ReloadPropagatedFrom": "php-fpm-MAIN.socket", "RemainAfterExit": "no", "RemoveIPC": "no", "Requires": "-.mount php-fpm-MAIN.socket system.slice sysinit.target", "RequiresMountsFor": "/var/tmp", "Restart": "on-failure", "RestartUSec": "100ms", "RestrictNamespaces": "no", "RestrictRealtime": "no", "RestrictSUIDSGID": "no", "Result": "success", "RootDirectoryStartOnly": "yes", "RuntimeDirectoryMode": "0755", "RuntimeDirectoryPreserve": "no", "RuntimeMaxUSec": "infinity", "SameProcessGroup": "no", "SecureBits": "0", "SendSIGHUP": "no", "SendSIGKILL": "yes", "Slice": "system.slice", "StandardError": "inherit", "StandardInput": "null", "StandardInputData": "", "StandardOutput": "journal", "StartLimitAction": "none", "StartLimitBurst": "3", "StartLimitIntervalUSec": "15s", "StartupBlockIOWeight": "[not set]", "StartupCPUShares": "[not set]", "StartupCPUWeight": "[not set]", "StartupIOWeight": "[not set]", "StateChangeTimestamp": "Fri 2026-10-16 20:44:14 EDT", "StateChangeTimestampMonotonic": "19240091220391", "StateDirectoryMode": "0755", "StatusErrno": "0", "StatusText": "Processes active: 0, idle: 0, Requests: 13540, slow: 0, Traffic: 0.00req/sec", "StopWhenUnneeded": "no", "SubState": "dead", "SuccessAction": "none", "SupplementaryGroups": "48 postdrop", "SyslogFacility": "3", "SyslogLevel": "6", "SyslogLevelPrefix": "yes", "SyslogPriority": "30", "SystemCallErrorNumber": "0", "TTYReset": "no", "TTYVHangup": "no", "TTYVTDisallocate": "no", "TasksAccounting": "yes", "TasksCurrent": "[not set]", "TasksMax": "102260", "TimeoutStartUSec": "7min", "TimeoutStopUSec": "30s", "TimerSlackNSec": "50000", "Transient": "no", "TriggeredBy": "php-fpm-MAIN.socket", "Type": "notify", "UID": "[not set]", "UMask": "0022", "UnitFilePreset": "disabled", "UnitFileState": "static", "User": "apache", "UtmpMode": "init", "WatchdogTimestampMonotonic": "0", "WatchdogUSec": "30s"}}
TASK [apnscp/install-services : Install php-fpm-MAIN.socket] ****************************************************************************************************************************************************************************************************************************
ok: [localhost] => (item=Copy /tmp/ansible.8sjnjs5i -> /etc/systemd/system/php-fpm-MAIN.socket) => {"ansible_loop_var": "file", "changed": false, "checksum": "c7501698bf62e01fc0b038efe021016b03407cda", "dest": "/etc/systemd/system/php-fpm-MAIN.socket", "file": {"dest": "/etc/systemd/system/php-fpm-MAIN.socket", "src": "/tmp/ansible.8sjnjs5i"}, "gid": 0, "group": "root", "mode": "0644", "owner": "root", "path": "/etc/systemd/system/php-fpm-MAIN.socket", "size": 405, "state": "file", "uid": 0}
TASK [apnscp/install-services : Enable php-fpm-MAIN.socket service] *********************************************************************************************************************************************************************************************************************
ok: [localhost] => {"changed": false, "enabled": true, "name": "php-fpm-MAIN.socket", "state": "started", "status": {"Accept": "no", "ActiveEnterTimestamp": "Fri 2026-10-16 20:44:15 EDT", "ActiveEnterTimestampMonotonic": "19240091677445", "ActiveExitTimestamp": "Fri 2026-10-16 20:44:14 EDT", "ActiveExitTimestampMonotonic": "19240091279255", "ActiveState": "active", "After": "-.mount system.slice sysinit.target", "AllowIsolate": "no", "AllowedCPUs": "", "AllowedMemoryNodes": "", "AmbientCapabilities": "", "AssertResult": "yes", "AssertTimestamp": "Fri 2026-10-16 20:44:15 EDT", "AssertTimestampMonotonic": "19240091585616", "Backlog": "128", "Before": "shutdown.target php-fpm-MAIN.service sockets.target", "BindIPv6Only": "default", "BindsTo": "php-fpm.service", "BlockIOAccounting": "no", "BlockIOWeight": "[not set]", "Broadcast": "no", "CPUAccounting": "no", "CPUAffinity": "", "CPUAffinityFromNUMA": "no", "CPUQuotaPerSecUSec": "infinity", "CPUQuotaPeriodUSec": "infinity", "CPUSchedulingPolicy": "0", "CPUSchedulingPriority": "0", "CPUSchedulingResetOnFork": "no", "CPUShares": "[not set]", "CPUUsageNSec": "[not set]", "CPUWeight": "[not set]", "CacheDirectoryMode": "0755", "CanFreeze": "no", "CanIsolate": "no", "CanReload": "yes", "CanStart": "yes", "CanStop": "yes", "CapabilityBoundingSet": "cap_chown cap_dac_override cap_dac_read_search cap_fowner cap_fsetid cap_kill cap_setgid cap_setuid cap_setpcap cap_linux_immutable cap_net_bind_service cap_net_broadcast cap_net_admin cap_net_raw cap_ipc_lock cap_ipc_owner cap_sys_module cap_sys_rawio cap_sys_chroot cap_sys_ptrace cap_sys_pacct cap_sys_admin cap_sys_boot cap_sys_nice cap_sys_resource cap_sys_time cap_sys_tty_config cap_mknod cap_lease cap_audit_write cap_audit_control cap_setfcap cap_mac_override cap_mac_admin cap_syslog cap_wake_alarm cap_block_suspend cap_audit_read cap_perfmon cap_bpf", "CollectMode": "inactive", "ConditionResult": "yes", "ConditionTimestamp": "Fri 2026-10-16 20:44:15 EDT", "ConditionTimestampMonotonic": "19240091585616", "ConfigurationDirectoryMode": "0755", "Conflicts": "shutdown.target", "ConsistsOf": "php-fpm-MAIN.service", "ControlGroup": "/system.slice/php-fpm-MAIN.socket", "ControlPID": "0", "DefaultDependencies": "yes", "DefaultMemoryLow": "0", "DefaultMemoryMin": "0", "DeferAcceptUSec": "0", "Delegate": "no", "Description": "PHP-FPM pool activation MAIN", "DevicePolicy": "auto", "DirectoryMode": "1111", "DynamicUser": "no", "EffectiveCPUs": "", "EffectiveMemoryNodes": "", "FailureAction": "none", "FileDescriptorName": "php-fpm-MAIN.socket", "FlushPending": "no", "FragmentPath": "/etc/systemd/system/php-fpm-MAIN.socket", "FreeBind": "no", "FreezerState": "running", "GID": "[not set]", "IOAccounting": "no", "IOSchedulingClass": "0", "IOSchedulingPriority": "0", "IOWeight": "[not set]", "IPAccounting": "no", "IPEgressBytes": "18446744073709551615", "IPEgressPackets": "18446744073709551615", "IPIngressBytes": "18446744073709551615", "IPIngressPackets": "18446744073709551615", "IPTOS": "-1", "IPTTL": "-1", "Id": "php-fpm-MAIN.socket", "IgnoreOnIsolate": "no", "IgnoreSIGPIPE": "yes", "InactiveEnterTimestamp": "Fri 2026-10-16 20:44:14 EDT", "InactiveEnterTimestampMonotonic": "19240091279255", "InactiveExitTimestamp": "Fri 2026-10-16 20:44:15 EDT", "InactiveExitTimestampMonotonic": "19240091587923", "InvocationID": "c4e98a011e41442ca8725da701e78438", "JobRunningTimeoutUSec": "infinity", "JobTimeoutAction": "none", "JobTimeoutUSec": "infinity", "KeepAlive": "no", "KeepAliveIntervalUSec": "0", "KeepAliveProbes": "0", "KeepAliveTimeUSec": "0", "KeyringMode": "shared", "KillMode": "control-group", "KillSignal": "15", "LimitAS": "infinity", "LimitASSoft": "infinity", "LimitCORE": "infinity", "LimitCORESoft": "0", "LimitCPU": "infinity", "LimitCPUSoft": "infinity", "LimitDATA": "infinity", "LimitDATASoft": "infinity", "LimitFSIZE": "infinity", "LimitFSIZESoft": "infinity", "LimitLOCKS": "infinity", "LimitLOCKSSoft": "infinity", "LimitMEMLOCK": "65536", "LimitMEMLOCKSoft": "65536", "LimitMSGQUEUE": "819200", "LimitMSGQUEUESoft": "819200", "LimitNICE": "0", "LimitNICESoft": "0", "LimitNOFILE": "262144", "LimitNOFILESoft": "1024", "LimitNPROC": "63913", "LimitNPROCSoft": "63913", "LimitRSS": "infinity", "LimitRSSSoft": "infinity", "LimitRTPRIO": "0", "LimitRTPRIOSoft": "0", "LimitRTTIME": "infinity", "LimitRTTIMESoft": "infinity", "LimitSIGPENDING": "63913", "LimitSIGPENDINGSoft": "63913", "LimitSTACK": "infinity", "LimitSTACKSoft": "8388608", "Listen": "/run/php-fpm/MAIN.socket (Stream)", "LoadState": "loaded", "LockPersonality": "no", "LogLevelMax": "-1", "LogRateLimitBurst": "0", "LogRateLimitIntervalUSec": "0", "LogsDirectoryMode": "0755", "Mark": "-1", "MaxConnections": "64", "MaxConnectionsPerSource": "0", "MemoryAccounting": "yes", "MemoryCurrent": "4096", "MemoryDenyWriteExecute": "no", "MemoryHigh": "infinity", "MemoryLimit": "infinity", "MemoryLow": "0", "MemoryMax": "infinity", "MemoryMin": "0", "MemorySwapMax": "infinity", "MessageQueueMaxMessages": "0", "MessageQueueMessageSize": "0", "MountAPIVFS": "no", "MountFlags": "", "NAccepted": "0", "NConnections": "0", "NRefused": "0", "NUMAMask": "", "NUMAPolicy": "n/a", "Names": "php-fpm-MAIN.socket", "NeedDaemonReload": "no", "Nice": "0", "NoDelay": "no", "NoNewPrivileges": "no", "NonBlocking": "no", "OOMScoreAdjust": "0", "OnFailureJobMode": "replace", "PassCredentials": "no", "PassPacketInfo": "no", "PassSecurity": "no", "Perpetual": "no", "PipeSize": "0", "Priority": "-1", "PrivateDevices": "no", "PrivateMounts": "no", "PrivateNetwork": "no", "PrivateTmp": "no", "PrivateUsers": "no", "PropagatesReloadTo": "php-fpm-MAIN.service", "ProtectControlGroups": "no", "ProtectHome": "no", "ProtectKernelModules": "no", "ProtectKernelTunables": "no", "ProtectSystem": "no", "ReceiveBuffer": "0", "RefuseManualStart": "no", "RefuseManualStop": "no", "RemoveIPC": "no", "RemoveOnStop": "yes", "RequiredBy": "php-fpm-MAIN.service", "Requires": "system.slice -.mount sysinit.target", "RequiresMountsFor": "/run/php-fpm/MAIN.socket", "RestrictNamespaces": "no", "RestrictRealtime": "no", "RestrictSUIDSGID": "no", "Result": "success", "ReusePort": "no", "RuntimeDirectory": "php-fpm", "RuntimeDirectoryMode": "0755", "RuntimeDirectoryPreserve": "no", "SameProcessGroup": "no", "SecureBits": "0", "SendBuffer": "0", "SendSIGHUP": "no", "SendSIGKILL": "yes", "Slice": "system.slice", "SocketGroup": "apache", "SocketMode": "0660", "SocketProtocol": "0", "SocketUser": "apache", "StandardError": "inherit", "StandardInput": "null", "StandardInputData": "", "StandardOutput": "journal", "StartLimitAction": "none", "StartLimitBurst": "5", "StartLimitIntervalUSec": "10s", "StartupBlockIOWeight": "[not set]", "StartupCPUShares": "[not set]", "StartupCPUWeight": "[not set]", "StartupIOWeight": "[not set]", "StateChangeTimestamp": "Fri 2026-10-16 20:44:15 EDT", "StateChangeTimestampMonotonic": "19240091677445", "StateDirectoryMode": "0755", "StopWhenUnneeded": "no", "SubState": "listening", "SuccessAction": "none", "SyslogFacility": "3", "SyslogLevel": "6", "SyslogLevelPrefix": "yes", "SyslogPriority": "30", "SystemCallErrorNumber": "0", "TTYReset": "no", "TTYVHangup": "no", "TTYVTDisallocate": "no", "TasksAccounting": "yes", "TasksCurrent": "0", "TasksMax": "102260", "TimeoutUSec": "1min 30s", "TimerSlackNSec": "50000", "Transient": "no", "Transparent": "no", "TriggerLimitBurst": "20", "TriggerLimitIntervalUSec": "2s", "Triggers": "php-fpm-MAIN.service", "UID": "[not set]", "UMask": "0022", "UnitFilePreset": "disabled", "UnitFileState": "enabled", "UtmpMode": "init", "WantedBy": "php-fpm.service", "Writable": "no"}}
TASK [apnscp/install-services : file] ***************************************************************************************************************************************************************************************************************************************************
ok: [localhost] => (item={'service': 'php-fpm', 'template': '../../install/templates/php-fpm-systemd-service.j2'}) => {"ansible_loop_var": "item", "changed": false, "item": {"service": "php-fpm", "template": "../../install/templates/php-fpm-systemd-service.j2"}, "path": "/tmp/ansible.482wagys", "state": "absent"}
ok: [localhost] => (item={'service': 'php-fpm-socket', 'template': '../../install/templates/php-fpm-systemd-socket.j2'}) => {"ansible_loop_var": "item", "changed": false, "item": {"service": "php-fpm-socket", "template": "../../install/templates/php-fpm-systemd-socket.j2"}, "path": "/tmp/ansible.8sjnjs5i", "state": "absent"}```
Looks fine. upcp -v should complete without issue since that’s the whole task. Provide the entire update log should it fail.
Failed again, looks like it was a different migration:
Nothing to migrate.
Migrating: 2025_08_05_130434_service-master-classes
[0/1] PLAY [localhost] ***************************************************************
[0/1] TASK [Gathering Facts] *********************************************************
ok: [localhost]
[0/1] TASK [common/acquire-lock : Validate lock existence] ***************************
ok: [localhost]
[0/1] TASK [common/acquire-lock : Acquire lock] **************************************
skipping: [localhost]
[0/1] TASK [common/acquire-lock : set_fact] ******************************************
ok: [localhost]
[0/1] TASK [common/acquire-lock : Check if PID /proc/3479068/comm present] ***********
ok: [localhost]
[0/1] TASK [common/acquire-lock : Verify process matches ansible] ********************
[0/1] TASK [common/acquire-lock : Save PID in /usr/local/apnscp/storage/run/.ansible.lock] ***
ok: [localhost]
[0/1] TASK [common/migrate : Gather all migration files] *****************************
[0/1] TASK [common/migrate : Locate migration files] *********************************
included: /usr/local/apnscp/resources/playbooks/migrations/2025_08_05_130434_service-master-classes.yml for localhost
[1/1] TASK [Add site@, group@ helpers] ***********************************************
[1/1] TASK [apnscp/install-services : Template services] *****************************
included: /usr/local/apnscp/resources/playbooks/roles/apnscp/install-services/tasks/template-service.yml for localhost
[1/1] TASK [apnscp/install-services : tempfile] **************************************
ok: [localhost]
[1/1] TASK [apnscp/install-services : set_fact] **************************************
ok: [localhost]
[1/1] TASK [apnscp/install-services : template] **************************************
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
[1/1] TASK [apnscp/install-services : Install systemd services] **********************
included: /usr/local/apnscp/resources/playbooks/roles/apnscp/install-services/tasks/install-service.yml for localhost
[1/1] TASK [apnscp/install-services : Install fsmount] *******************************
ok: [localhost] => (item=Copy /tmp/ansible.uzkkfurh -> /etc/systemd/user/fsmount.init)
ok: [localhost] => (item=Copy fsmount.service -> /etc/systemd/system/fsmount.service)
[1/1] TASK [apnscp/install-services : {{ systemd.enabled | bool | default(true) | ternary('Enable','Disable') }} {{ name }} service] ***
[1/1] TASK [apnscp/install-services : Install populate-tmp] **************************
ok: [localhost] => (item=Copy fstmp.init -> /etc/systemd/user/fstmp.init)
ok: [localhost] => (item=Copy populate-tmp.service -> /etc/systemd/system/populate-tmp.service)
[1/1] TASK [apnscp/install-services : Install virtualcroncleanstate] *****************
ok: [localhost] => (item=Copy virtualcroncleanstate.service -> /etc/systemd/system/virtualcroncleanstate.service)
[1/1] TASK [apnscp/install-services : Install virtualcron] ***************************
ok: [localhost] => (item=Copy virtualcron.init -> /etc/systemd/user/virtualcron.init)
ok: [localhost] => (item=Copy virtualcron.service -> /etc/systemd/system/virtualcron.service)
[1/1] TASK [apnscp/install-services : Install virtualhosting] ************************
ok: [localhost] => (item=Copy virtualhosting.init -> /etc/systemd/user/virtualhosting.init)
ok: [localhost] => (item=Copy virtualhosting.service -> /etc/systemd/system/virtualhosting.service)
[1/1] TASK [apnscp/install-services : Install rc-local] ******************************
ok: [localhost] => (item=Copy rc-local.service -> /etc/systemd/system/rc-local.service)
[1/1] TASK [apnscp/install-services : Enable rc-local service] ***********************
ok: [localhost]
[1/1] TASK [apnscp/install-services : Install bwcron.timer] **************************
ok: [localhost] => (item=Copy bwcron.timer -> /etc/systemd/system/bwcron.timer)
ok: [localhost] => (item=Copy /tmp/ansible.d_btz3y7 -> /etc/systemd/system/bwcron.service)
[1/1] TASK [apnscp/install-services : Install metricscron.timer] *********************
ok: [localhost] => (item=Copy metricscron.timer -> /etc/systemd/system/metricscron.timer)
ok: [localhost] => (item=Copy /tmp/ansible.k5ylwynk -> /etc/systemd/system/metricscron.service)
[1/1] TASK [apnscp/install-services : Install apnscp-housekeeping.timer] *************
ok: [localhost] => (item=Copy apnscp-housekeeping.timer -> /etc/systemd/system/apnscp-housekeeping.timer)
ok: [localhost] => (item=Copy /tmp/ansible._2jlhj48 -> /etc/systemd/system/apnscp-housekeeping.service)
[1/1] TASK [apnscp/install-services : Disable apnscp-housekeeping.timer service] *****
ok: [localhost]
[1/1] TASK [apnscp/install-services : Install apnscp-flare-check.timer] **************
ok: [localhost] => (item=Copy apnscp-flare-check.timer -> /etc/systemd/system/apnscp-flare-check.timer)
ok: [localhost] => (item=Copy /tmp/ansible.fy_6w2al -> /etc/systemd/system/apnscp-flare-check.service)
[1/1] TASK [apnscp/install-services : Enable apnscp-flare-check.timer service] *******
ok: [localhost]
[1/1] TASK [apnscp/install-services : Install upcp.timer] ****************************
ok: [localhost] => (item=Copy /tmp/ansible.dxkk0z4z -> /etc/systemd/system/upcp.timer)
ok: [localhost] => (item=Copy /tmp/ansible.0e1fhibu -> /etc/systemd/system/upcp.service)
[1/1] TASK [apnscp/install-services : Enable upcp.timer service] *********************
ok: [localhost]
[1/1] TASK [apnscp/install-services : Install platform-scrub.timer] ******************
ok: [localhost] => (item=Copy /tmp/ansible.o17t_6t9 -> /etc/systemd/system/platform-scrub.timer)
ok: [localhost] => (item=Copy /tmp/ansible.d0ms0p_6 -> /etc/systemd/system/platform-scrub.service)
[1/1] TASK [apnscp/install-services : Enable platform-scrub.timer service] ***********
ok: [localhost]
[1/1] TASK [apnscp/install-services : Install group@.service] ************************
ok: [localhost] => (item=Copy group@.service -> /etc/systemd/system/group@.service)
[1/1] TASK [apnscp/install-services : Disable group@.service service] ****************
ok: [localhost]
[1/1] TASK [apnscp/install-services : Install site@.service] *************************
ok: [localhost] => (item=Copy site@.service -> /etc/systemd/system/site@.service)
[1/1] TASK [apnscp/install-services : Disable site@.service service] *****************
ok: [localhost]
[1/1] TASK [apnscp/install-services : file] ******************************************
ok: [localhost] => (item={'service': 'fsmount', 'template': 'fsmount.init.j2'})
ok: [localhost] => (item={'service': 'bwcron', 'template': 'bwcron.service.j2'})
ok: [localhost] => (item={'service': 'metricscron', 'template': 'metricscron.service.j2'})
ok: [localhost] => (item={'service': 'apnscp-housekeeping', 'template': 'apnscp-housekeeping.service.j2'})
ok: [localhost] => (item={'service': 'apnscp-flare-check', 'template': 'apnscp-flare-check.service.j2'})
ok: [localhost] => (item={'service': 'upcp', 'template': 'upcp.service.j2'})
ok: [localhost] => (item={'service': 'upcp-timer', 'template': 'upcp.timer.j2'})
ok: [localhost] => (item={'service': 'platform-scrub-timer', 'template': 'platform-scrub.timer.j2'})
ok: [localhost] => (item={'service': 'platform-scrub', 'template': 'platform-scrub.service.j2'})
[1/1] TASK [Add php-fpm@ help] *******************************************************
[1/1] TASK [php/build-from-source : Assert /etc/php-fpm.d is directory] **************
ok: [localhost]
[1/1] TASK [php/build-from-source : Create PHP-FPM logging] **************************
ok: [localhost]
[1/1] TASK [php/build-from-source : Copy PHP-FPM templates] **************************
ok: [localhost] => (item={'src': 'php-fpm-conf.j2', 'dest': '/etc/php-fpm.conf'})
ok: [localhost] => (item={'src': 'php-fpm-pool.j2', 'dest': '/etc/php-fpm.d/MAIN.conf'})
[1/1] TASK [Install services] ********************************************************
ok: [localhost]
ok: [localhost]
  msg: 'AnsibleUndefinedVariable: ''php_fst_service'' is undefined'
[1/1] PLAY RECAP *********************************************************************
localhost                  : ok=85   changed=0    unreachable=0    failed=1    skipped=10   rescued=0    ignored=0
(5a0c8dfc-fa87-5906-a5fa-36ea57f51bac RuntimeException) EXCEPTION: STDOUT:
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
ok: [localhost]
Migrations have not completed yet. Update cannot proceed!
Run the following command to apply migrations, correcting failure as necessary:
To force an update to latest code, run the following command:
cd /usr/local/apnscp && upcp -f && ./artisan migrate --force```
That would make more sense. Moving from .48 to .49.
cpcmd scope:set cp.bootstrapper php_fst_service siteinfo
Then give it another go.
That did it. Thanks for the quick replies Matt!
