Whitelist for WordPress Admin's IP (e.g. Rapid Backend Calls From Plugins)
Can anyone point me to any docs for the current procedure to whitelist an IP for a new WordPress site?
I see WordPress | ApisCP Docs et al.
In the past we had false positive block of client’s WAN (dynamic) IP address due to plugin actions generating rapid calls (appearing as bad actor.)
As a result we had to manually allow (recidive, mod-evasive, etc?), e.g.
# cpcmd scope:set apache.evasive-whitelist '<IP_ADDRESS>'
# cpcmd scope:set apache.shield-whitelist <IP_ADDRESS>
Asking specifically because I think I saw some mention of changes to firewall/blocking and I have not kept up.
Edit: To clarify, the main issue with WordPress specifically, was hitting the 429 resource limit error pages due to plugins generated requests rapidly.
evasive-whitelist is an alias to shield-whitelist. What evidence do you have to the contrary?
Shield introduces curves to discriminate against aggressive bots. You can disable DoS prevention entirely by setting shield,enabled=0 for a site. There’s also documentation, updated for Shield published sometime last year, when the feature was kicked out.
