Is there a proper way to load Googlebot’s lists into firewalld to make sure these never get banned? Also, is there a smart way to keep the lists updated too?
Building off this example, Mod evasive adjustment - per site? - #2 by msaladna
curl -o- https://developers.google.com/static/search/apis/ipranges/googlebot.json | jq '.prefixes[][]' | while read IP ; do
echo $IP
cpcmd rampart:whitelist $IP
done
Is there a way to purge all “manually” whitelisted IPs too? That could be useful when refreshing the ranges, making sure no previously whitelisted and now decommissioned remain dangling in firewalld.
Like keeping a copy of the file, then re-running something along the lines of:
cat googlebot.json | jq '.prefixes[][]' | while read IP ; do
echo "Removing $IP"
cpcmd rampart:whitelist $IP remove
done
This should do the trick, right?
Yes, that would remove from the whitelist.
