It looks like something broke recently or overnight on a couple of servers. Users get a 500 error attempting to hit the login endpoint as well as SSO. This affects admin login as well not just uses.
The only log entry is in /usr/local/apnscp/storage/logs/php-fpm.log Nothing in start.log at all.
[12-Aug-2026 12:12:08 UTC] PHP Fatal error: Uncaught Error: Call to a member function getTrace() on array in /usr/local/apnscp/lib/apnscpcore.php:63
Stack trace:
#0 /usr/local/apnscp/lib/error_reporter.php(256): Error_Reporter\ReportFilterInterface@anonymous->filter(128, 'Call to a membe...', '/usr/local/apns...', 63, Array)
#1 /usr/local/apnscp/lib/error_reporter.php(162): Error_Reporter::handle_error(128, 'Call to a membe...', '/usr/local/apns...', 63, Object(Error))
#2 [internal function]: Error_Reporter::handle_exception(Object(Error))
#3 {main}
thrown in /usr/local/apnscp/lib/apnscpcore.php on line 63
Both servers are on the following version:
revision: ec46f06a51e8f61d4ea9cb9148abc641945989a4
timestamp: 1786455299
ver_pre: 79-gec46f06a5
checksum: 13527cc817c8106
FWIW, front-end debug enabled allows me to login and there are no errors displayed at all. As soon as I turn off the front-end debug, it fails with 500 errors again.
Only confirmed the issue on 2 servers so far, but it’s early.
