Apply Recursively to Change Permissions doesn't work as intended
Here are some helpful considerations when filing a bug:
- What version of apnscp are you running?
43c4cf6b93dffdf9e7ba206a569aaf1cfc9de8f4
- Which version of RHEL or CentOS are you using?
AlmaLinux release 8.10 (Cerulean Leopard)
- Can you reproduce this bug reliably? Provide steps. If not, provide steps to the best of your recollection.
Under Change Permissions in File Manager, the “apply recursively” option only affects the contents of the immediate directory, not the contents of sub-directories. If you apply 775 to a folder, folders and files inside of it will have these permissions, but no subsequent levels.
Thanks for the bug report. This is fixed in edge. To hop on edge until the next release:
