The token seems to be working, at least some of the time. cpcmd -o json admin:collect '[]' | jq -r 'values[].domain' | while read DOMAIN ; do EditDomain -c dns,key='DEFAULT' -D $DOMAIN; done helped clear up some problems with some domains.
I did some testing to try to narrow down a reproducible error case, and I found one. Deleting the default MX record consistently fails. To make sure it wasn’t caused by some odd manual change I made, I deleted the record from my Cloudflare dashboard, then from the ApisCP dashboard I ran “Restore default MX” which threw errors on other records but did in fact re-create the MX record. After that, the “Delete” button still errors with:
Record `@.domain.com' (rr: `MX', param: `10 mail.domain.com') does not exist
For what it’s worth, below is the output when I try to run the test suite. I’m not sure I understand how it’s supposed to work, though. It’s erroring because the domain debug.test is not a domain that my Cloudflare account has access to use. So it’s not clear to me that the failure shows any unanticipated problem.
# ./phpunit.php -v dns/ResourceRecordTest.php
PHPUnit 9.6.22 by Sebastian Bergmann and contributors.
Runtime: PHP 8.1.21
Configuration: /usr/local/apnscp/tests/phpunit.xml
INFO : no billing identifier specified for site, generated `apnscp-JYGKMQRN'
0. Error_Reporter::add_info("no billing identifier specified for site, generated `%s'", ["apnscp-JYGKMQRN"])
[/usr/local/apnscp/lib/log_wrapper.php:108]
1. info("no billing identifier specified for site, generated `%s'", "apnscp-JYGKMQRN")
[/usr/local/apnscp/lib/Opcenter/Service/Validators/Billing/Invoice.php:35]
2. Opcenter\Service\Validators\Billing\Invoice->valid("apnscp-JYGKMQRN")
[/usr/local/apnscp/lib/Opcenter/Service/ConfigurationContext.php:568]
3. Opcenter\Service\ConfigurationContext->check("invoice", "apnscp-JYGKMQRN")
[/usr/local/apnscp/lib/Opcenter/Service/ConfigurationContext.php:165]
4. Opcenter\Service\ConfigurationContext->preflight()
[/usr/local/apnscp/lib/Opcenter/SiteConfiguration.php:736]
5. Opcenter\SiteConfiguration->verify("billing", Opcenter\Service\ConfigurationContext)
[/usr/local/apnscp/lib/Opcenter/SiteConfiguration.php:655]
6. Opcenter\SiteConfiguration->verifyAll()
[/usr/local/apnscp/lib/Opcenter/Account/Create.php:183]
7. Opcenter\Account\Create->installServices("FILESYSTEM.created", Opcenter\Filesystem)
[/usr/local/apnscp/lib/Event/Cardinal.php:143]
8. Event\Contracts\Subscriber@anonymous/usr/local/apnscp/lib/Event/Cardinal.php:132$d1->update("FILESYSTEM.created", Opcenter\Filesystem)
[/usr/local/apnscp/lib/Event/Manager.php:187]
9. Event\Manager->fire("FILESYSTEM.created", Opcenter\Filesystem)
[/usr/local/apnscp/lib/Event/Cardinal.php:172]
10. Event\Cardinal::fire(["FILESYSTEM", "created"], Opcenter\Filesystem)
[/usr/local/apnscp/lib/Opcenter/Filesystem.php:79]
11. Opcenter\Filesystem->populate()
[/usr/local/apnscp/lib/Opcenter/Filesystem.php:47]
12. Opcenter\Filesystem::create("site17", null)
[/usr/local/apnscp/lib/Opcenter/Account/Create.php:154]
13. Opcenter\Account\Create->exec()
[/usr/local/apnscp/lib/Opcenter/Account/Ephemeral.php:113]
14. Opcenter\Account\Ephemeral->exec()
[/usr/local/apnscp/lib/Opcenter/Account/Ephemeral.php:104]
15. Opcenter\Account\Ephemeral::create([[domain:"debug.test"]])
[/usr/local/apnscp/tests/TestHelpers.php:45]
16. TestHelpers::create("debug.test")
[/usr/local/apnscp/tests/dns/ResourceRecordTest.php:18]
17. ResourceRecordTest->testProviders()
[/usr/local/apnscp/vendor/phpunit/phpunit/src/Framework/TestCase.php:1617]
18. PHPUnit\Framework\TestCase->runTest()
[/usr/local/apnscp/vendor/phpunit/phpunit/src/Framework/TestCase.php:1223]
19. PHPUnit\Framework\TestCase->runBare()
[/usr/local/apnscp/vendor/phpunit/phpunit/src/Framework/TestResult.php:729]
20. PHPUnit\Framework\TestResult->run(ResourceRecordTest)
[/usr/local/apnscp/vendor/phpunit/phpunit/src/Framework/TestCase.php:973]
21. PHPUnit\Framework\TestCase->run(PHPUnit\Framework\TestResult)
[/usr/local/apnscp/vendor/phpunit/phpunit/src/Framework/TestSuite.php:685]
22. PHPUnit\Framework\TestSuite->run(PHPUnit\Framework\TestResult)
[/usr/local/apnscp/vendor/phpunit/phpunit/src/TextUI/TestRunner.php:651]
23. PHPUnit\TextUI\TestRunner->run(PHPUnit\Framework\TestSuite, [listGroups:false, listSuites:false, listTests:false, listTestsXml:false, loader:null, useDefaultConfiguration:true, [[[verbose:true, ]]]])
[/usr/local/apnscp/vendor/phpunit/phpunit/src/TextUI/Command.php:146]
24. PHPUnit\TextUI\Command->run(["./phpunit.php", "-v", "dns/ResourceRecordTest.php"], true)
[/usr/local/apnscp/vendor/phpunit/phpunit/src/TextUI/Command.php:99]
25. PHPUnit\TextUI\Command::main()
[/usr/local/apnscp/tests/phpunit.php:70]
INFO : no mysql database prefix specified - suggesting `debu_'
0. Error_Reporter::add_info("no %(type)s database prefix specified - suggesting `%(prefix)s'", [[type:"mysql", prefix:"debu_"]])
1. info("no %(type)s database prefix specified - suggesting `%(prefix)s'", [type:"mysql", prefix:"debu_"])
[/usr/local/apnscp/lib/Opcenter/Service/Validators/Mysql/Dbaseprefix.php:61]
2. Opcenter\Service\Validators\Mysql\Dbaseprefix->valid("debu_")
3. Opcenter\Service\ConfigurationContext->check("dbaseprefix", "debu_")
5. Opcenter\SiteConfiguration->verify("mysql", Opcenter\Service\ConfigurationContext)
WARNING: cgroup usage is strongly encouraged when using PHP-FPM - enable with cgroup,enabled=1
0. Error_Reporter::add_warning("cgroup usage is strongly encouraged when using PHP-FPM - enable with cgroup,enabled=1", )
[/usr/local/apnscp/lib/log_wrapper.php:95]
1. warn("cgroup usage is strongly encouraged when using PHP-FPM - enable with cgroup,enabled=1")
[/usr/local/apnscp/lib/Opcenter/Service/Validators/Apache/Jail.php:59]
2. Opcenter\Service\Validators\Apache\Jail->valid(1)
3. Opcenter\Service\ConfigurationContext->check("jail", 1)
5. Opcenter\SiteConfiguration->verify("apache", Opcenter\Service\ConfigurationContext)
INFO : no bandwidth rollover date specified, using day of month, `16'
0. Error_Reporter::add_info("no bandwidth rollover date specified, using day of month, `%s'", [16])
1. info("no bandwidth rollover date specified, using day of month, `%s'", 16)
[/usr/local/apnscp/lib/Opcenter/Service/Validators/Bandwidth/Rollover.php:27]
2. Opcenter\Service\Validators\Bandwidth\Rollover->valid(16)
3. Opcenter\Service\ConfigurationContext->check("rollover", 16)
5. Opcenter\SiteConfiguration->verify("bandwidth", Opcenter\Service\ConfigurationContext)
INFO : No password specified - generating random password: `Bn2b0xYf7HA7Gkal4DNavwYWmLiKNsmL'
0. Error_Reporter::add_info("No password specified - generating random password: `%s'", ["Bn2b0xYf7HA7Gkal4DNavwYWmLiKNsmL"])
1. info("No password specified - generating random password: `%s'", "Bn2b0xYf7HA7Gkal4DNavwYWmLiKNsmL")
[/usr/local/apnscp/lib/Opcenter/Service/Validators/Auth/Tpasswd.php:33]
2. Opcenter\Service\Validators\Auth\Tpasswd->valid("Bn2b0xYf7HA7Gkal4DNavwYWmLiKNsmL")
3. Opcenter\Service\ConfigurationContext->check("tpasswd", "Bn2b0xYf7HA7Gkal4DNavwYWmLiKNsmL")
5. Opcenter\SiteConfiguration->verify("auth", Opcenter\Service\ConfigurationContext)
INFO : allocated port range [40110,40119] for account
0. Error_Reporter::add_info("allocated port range [4%03u0,4%03u9] for account", [11, 11])
1. info("allocated port range [4%03u0,4%03u9] for account", 11, 11)
[/usr/local/apnscp/lib/Opcenter/Service/Validators/Ssh/PortIndex.php:45]
2. Opcenter\Service\Validators\Ssh\PortIndex->valid(11)
3. Opcenter\Service\ConfigurationContext->check("port_index", 11)
5. Opcenter\SiteConfiguration->verify("ssh", Opcenter\Service\ConfigurationContext)
INFO : DNS not configured for `debug.test', bypassing DNS hooks
0. Error_Reporter::add_info("DNS not configured for `%s', bypassing DNS hooks", ["debug.test"])
1. info("DNS not configured for `%s', bypassing DNS hooks", "debug.test")
[/usr/local/apnscp/lib/Opcenter/Service/Validators/Dns/Enabled.php:51]
2. Opcenter\Service\Validators\Dns\Enabled->populate(Opcenter\SiteConfiguration)
[/usr/local/apnscp/lib/Opcenter/Service/Validators/Common/Enabled.php:126]
3. Opcenter\Service\Validators\Common\Enabled->fire(["service"], Opcenter\SiteConfiguration)
[/usr/local/apnscp/lib/Opcenter/Service/Validators/Common/Enabled.php:94]
4. Opcenter\Service\Validators\Common\Enabled->update("service.success", Opcenter\SiteConfiguration)
5. Event\Contracts\Subscriber@anonymous/usr/local/apnscp/lib/Event/Cardinal.php:132$d1->update("service.success", Opcenter\SiteConfiguration)
6. Event\Manager->fire("service.success", Opcenter\SiteConfiguration)
7. Event\Cardinal::fire(["service", "success"], Opcenter\SiteConfiguration)
[/usr/local/apnscp/lib/Opcenter/Account/Create.php:209]
8. Opcenter\Account\Create->installServices("FILESYSTEM.created", Opcenter\Filesystem)
9. Event\Contracts\Subscriber@anonymous/usr/local/apnscp/lib/Event/Cardinal.php:132$d1->update("FILESYSTEM.created", Opcenter\Filesystem)
10. Event\Manager->fire("FILESYSTEM.created", Opcenter\Filesystem)
11. Event\Cardinal::fire(["FILESYSTEM", "created"], Opcenter\Filesystem)
12. Opcenter\Filesystem->populate()
13. Opcenter\Filesystem::create("site17", null)
14. Opcenter\Account\Create->exec()
15. Opcenter\Account\Ephemeral->exec()
16. Opcenter\Account\Ephemeral::create([[domain:"debug.test"]])
17. TestHelpers::create("debug.test")
18. ResourceRecordTest->testProviders()
19. PHPUnit\Framework\TestCase->runTest()
20. PHPUnit\Framework\TestCase->runBare()
21. PHPUnit\Framework\TestResult->run(ResourceRecordTest)
22. PHPUnit\Framework\TestCase->run(PHPUnit\Framework\TestResult)
23. PHPUnit\Framework\TestSuite->run(PHPUnit\Framework\TestResult)
24. PHPUnit\TextUI\TestRunner->run(PHPUnit\Framework\TestSuite, [listGroups:false, listSuites:false, listTests:false, listTestsXml:false, loader:null, useDefaultConfiguration:true, [[[verbose:true, ]]]])
25. PHPUnit\TextUI\Command->run(["./phpunit.php", "-v", "dns/ResourceRecordTest.php"], true)
26. PHPUnit\TextUI\Command::main()
F 1 / 1 (100%){ }
Time: 00:01.920, Memory: 43.00 MB
There was 1 failure:
1) ResourceRecordTest::testProviders
Failed asserting that actual size 0 matches expected size 2.
/usr/local/apnscp/tests/dns/helpers/RecordFramework.php:284
/usr/local/apnscp/tests/dns/ResourceRecordTest.php:35
FAILURES!
Tests: 1, Assertions: 65, Failures: 1.
