Tested on OS X with Safari. MS Edge is okay.
Which version? Seems OK on 14.0.1, 14.0.2, and 14.0.3 from what others are testing.
Can you try adding this snippet and see how that works out?
#ui-menu {
display: block;
Hi @msaladna I’m using Safari 14.1 (16611.1.21.161.6) on Big Sur 11.3.1 (20E241).
Sorry @anatoli where and how should I put that snippet?
Thank you!
The issue also happened on material theme;
Switched to EDGE, but still have issue. Flushed the cache, private mode tab, still no luck.
–edit:
Sorry my terminal went haywire so can’t copy text:
After switch to edge:
[root@sg-ap2 ~]# cpcmd scope:set cp.update-policy edge
[root@sg-ap2 ~]# upcp
From https://gitlab.com/apisnetworks/apnscp
* branch master -> FETCH_HEAD
Already up-to-date.
./public/apnscp.wsdl
./storage/.upcp.failure
./storage/tmp/agent-root
./storage/run/httpd.pid
./storage/run/apnscpd.pid
./storage/cache/config.php
./storage/opcenter/mappings/domainmap.tch
./lib/intellisense.php
Compiled services and packages files removed!
Nothing to migrate.
Nothing to migrate.
[root@sg-ap2 ~]# systemctl restart apiscp
