When trying changing the limits, it fails with “Postback failed!!!” message.
Doesnt work with CLI either.
Version: 3.2.0-38ea4fc33
Thanks for the bug report. This is fixed on edge. To hop on edge until the next release:
Then run upcp.
I did - still same issue.
I tried
and then
I could see some updates in terminal, but bug still persist.
Has the panel restarted? Try systemctl restart apiscp just in case…
Yes i tried to restart - Same issue
What’s cpcmd misc:cp-version report?
[root@srv ~]# cpcmd misc:cp-version
revision: bd2324ff7d6c628523c929c8123367818a3d5e9f
timestamp: 1728927526
ver_pre: bd2324ff7
Works fine for me. See attached screencap. Note there is no indication of “Postback error” and the command, once issued, is added to Scope History. Formatting may look slightly different (actual value vs “Array”). This was a rendering bug in multidimensional arrays that’s been pushed upstream now.
Please try to change the “fsize” value and see if it occurs at you.
Still lgtm. See attached.
That makes it even more concerning… I will shoot an email.
